Home > Technical (L322) > 2011 4.4 tdv8 high tick over and viscous fan on all the time |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Read the live values for all temperature sensors, including transmission - I know you say the coolant temp. was showing 'normal', there will be a high temperature, or reported high temperature somewhere.
14th Jan 2023 9:13pm |
Seancod Member Since: 08 Jun 2019 Location: Cornwall Posts: 20 |
Thanks for that, makes sense, I will investigate tomorrow. |
14th Jan 2023 11:03pm |
Best to do with a completely cold car, that way any values that are not at ambient or close to it will immediately stick out. |
14th Jan 2023 11:13pm |
Thanks Phoenix for putting us on the right track. Transmission all checked out ok but turned out to be an issue with the air con. Must need a regas and comes on in auto mode. Switched off and all back to normal, big relief, thought this could be big money. |
15th Jan 2023 1:06pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2701 |
Don't assume it's just a regas as the compressor is a common fail on these cars. Plenty of info here much of it supplied by Phoenix's expertise. 2012 TDV8 Vogue (L322) |
15th Jan 2023 1:13pm |
Yes, could be a compressor fault, will check it out when the weather gets better. At least I can still use it just with no AC. |
15th Jan 2023 3:32pm |
