![]() | Home > Technical (L322) > Iffy alternator? |
| Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929
Get a volt reader on the battery directly mate and make sure it's sending out the same voltage as what gap is saying but I'd say likely hood is its an alternator job |
| philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527
For your reference, I fitted a new alternator a few weeks ago, and at idle I get 13.7-14 and as soon as revs are applied or when driving 14.7. |
| Mike_A4 Member Since: 01 Jan 2023 Location: Suffolk Posts: 34
Those look more like the values I would expect.
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3403
Facelift models have a 'smart' battery charging system which varies the charging voltage depending on load so if you are not seeing a constant 14.7v it's normal 2012 TDV8 Vogue (L322) |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
Exactly - don't rely on 'traditional' charge voltages being present all the time for pretty much any vehicle designed & built in this century, in certain circumstances, you can see system voltages of 12.6VDC, which is 'as intended'. 11.7VDC definitely points to a defective charge system, interesting that your starter battery was flat, that usually points to a defective rectifier pack, personally I'd recommend that you disconnect the battery to prevent it being over-discharged like the one you replaced (which would probably need replacement as well as the alternator anyway). you may also detect the alternator giving off some heat, even with a cold engine. |
[sigh]
Is this a dealer? they should be well able to remove the alternator! I've done a fair few on the 4.4TDV8 in the past and don't remember anything too onerous about it.
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6838
Take a look at this thread on alternator swaps- https://www.fullfatrr.com/forum/topic23089...alternator Got - 2017 SDV8 Autobiography in Loire Blue
I have it back – at last!
| All times are GMT |
