Home > My Range Rover > Project TDV8 |
Fatboy Slim Member Since: 21 Aug 2021 Location: Bridgend Posts: 31 |
Hi all. |
15th Jan 2023 3:47pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7631 |
Welcome.
15th Jan 2023 4:28pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2973 |
I’m doing a few jobs on a friends TDV8 just now which is intermittently throwing a high fuel pressure fault as well.
19th Feb 2023 10:50pm |
Will keep you posted! This one does it immediately on startup, if you clear the fault with it running, you can hear the the injectors bark a bit as the rail pressure rises, then the fault becomes active and cuts the rail pressure back again.....
19th Feb 2023 11:02pm |
If you start it and take the revs straight to 1500rpm does it stop it?
19th Feb 2023 11:14pm |
Good question, I don't think it'll actually let me rev it to 1500 without throwing the P0088 up and derating. It's an interesting one! I'm slightly leaning towards an ECU issue at the moment, I've ordered a genuine rail pressure sensor for it which should be with me this week, when that turns up I'll see what it does and hopefully scope the signal from it to get an idea of what's what. Information on these 3.6s seems a bit sketchy sadly, I'd love to know what the rail pressure map is for these at startup just to see what the desired pressure is.
19th Feb 2023 11:24pm |
The trick with this one is to start it with your foot slightly on the throttle so it doesn’t get a chance to idle.
19th Feb 2023 11:32pm |
Much appreciated! will report back with anything I find |
19th Feb 2023 11:34pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
Fatboy Slim, where did you get the pressure control valve, all I have read its only available with the complete HP pump. I have had very random P117e00 codes after going into limp mode which points to the valve. When I say random, I can go months in between the fault, turn off the engine, count to 10, restart and good to go until the next random episode. I thought I had cured it by removing the plug, adding new corrugated insulation and some snake oil 2stroke oil in the fuel. after 4 months it happened again yesterday. Do you think the valve could be swapped with the pump still in situ? 2007 TDV8 VSE
25th Feb 2023 9:58am |
Hi Wayne
25th Feb 2023 10:24am |
There was a really good diesel shop on the outskirts of Melbournes CBD I used to deal with when I was working in Aus....Will see if I can find their details. They were mega helpful and were shipping bits of pump out to me all over the country |
25th Feb 2023 10:29am |
https://www.cornells.com.au/ pretty sure it was these guys |
25th Feb 2023 10:33am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2307 |
Check the pressure sensor link harness connector as referred to in LTB01083. |
25th Feb 2023 11:40am |
I thought that only applies to the 4.4? I did check it on mine, in fact I made an overlay harness from the rail pressure sensor to the engine ECU |
25th Feb 2023 1:29pm |
