Home > My Range Rover > Looks like the honeymoon might be over
Doonhamer
Got my 11 plate L322 TDV8 4.4 just before Christmas - chalk and cheese from its TD6 predecessor - and I love it! However, and you just knew there would be a ‘however’, on a short run to take my wife over to Basingstoke to deliver presents for our grandson who is 1 on Tuesday, within the space of 5 miles I got so many warning messages, both amber and red, that I had to turn round and ended up limping home. Can’t quite remember the order but Adaptive Dynamics came up first, followed by low battery (red), gearbox, . . . . to be honest, too many separate warnings to take note of! Managed to limp home, plugged it into battery charger with the hope that I can at least get it to my local independent LR garage on the way to work tomorrow morning so they can run a diagnostic. I’m hoping it’s just something simple like battery or alternator - but at least it will be on warranty. Watch this space . . . L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Suzuki Grand Vitara XL7 - sold
Mitsubishi Pajero 2.8 - part ex'd
Hyundai Santa Fe 2.0 td - sold
Mitsubishi Pajero 2.8 - sold
Post #653657 15th Jan 2023 8:47pm
i think you could be right...battery check first and then the alternator...good luck. Thumbs Up Thumbs Up ... - .- -.
Post #653671 15th Jan 2023 10:00pm
Doonhamer
Thank you, Stan - had it for such a short period of time that I didn’t even manage to ask for a ‘FULLFATRR’ sticker for it! 😫 L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #653678 15th Jan 2023 10:47pm
Dolphinboy
sounds like alternator or battery. latter is cheapest so hopefully it's that. These models do suck up the juice - Just leaving a door open or the radio on for a little while will reward you with a ping warning to 'start the engine'!
However welcome to one of the best L322 models - as you say, chalk and cheese to the TD6.
(is that a REME cap badge Censored take? if so you should have no probs on 'first parading'!)
Post #653687 16th Jan 2023 12:14am
GraemeS
Australia
The alternators can go short circuit so keep an eye on your charger.
Post #653696 16th Jan 2023 6:46am
DrRob
My cash is on a battery issue. There is inevitably going to be a few issues with a new-to-you car but after a period of bedding in (and some cash) all will be good. Just keep the faith Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #653697 16th Jan 2023 8:29am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
In my experience (I have had both fail in last 18 months) if you did not get a generator fault it is battery. when my battery had a couple of bad cells even when fully charged after starting i would get all those same errors. most home battery testers are not advanced enough to tell you about cell damage.
Changing the battery was an immediate fix.
When my alternator went a few weeks ago i just got a Generator Error warning and sure enough when i plugged in a fault finder i could see it was charging at 10.4 volts.
Changing the alternator fixed this. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #653699 16th Jan 2023 8:56am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I wouldn't panic too much. As previously stated alternator or battery (poss wiring).
As you know these vehicles just love to give you a dash nightmare for the stupid of reasons Mr. Green
Post #653706 16th Jan 2023 10:27am
kevinp
Doonhammer, I recently replaced all the pulleys on my car and while it was all apart I changed my alternator. It was working perfectly and you are welcome to it if you pay for postage.
I realise you may not want to take a chance on how long it would last for the work involved but the offer is there.
Kev.
Post #653717 16th Jan 2023 12:44pm
johnboyairey
My car had an alternator fail, with all the bongs bonging, suspension, gearbox, etc…and then some smoke from the alternator area, which prompted me to shut off, and disconnect the battery asap. The negative cable was getting warm, so I had a direct short on the battery… changed the alternator, and everything fine. The regulator diode pack is a weak point. But my car was on 200,000, and seemingly original alternator!
Post #653775 17th Jan 2023 10:43am
Doonhamer
All is well - new alternator and battery fitted, apparently the garage that fitted the alternator at the start of last year didn’t fit the main electrical connection to the alt correctly . . . there’s a lot to be said for using a garage that knows what they’re doing. Thank you to Newbury 4x4 for sorting the problem out, wouldn’t use anywhere else! 👍 L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #654301 21st Jan 2023 9:20pm
Doonhamer
PS Kevinp- thank you for your kind offer, events have rather overtaken things and to be honest, I’m happier with a new one and the associated warranty 👍 L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #654302 21st Jan 2023 9:25pm
Doonhamer
The honeymoon is back on - found myself driving to work at 07:00 this morning, heated seat on full chat and heated steering wheel on, thinking to myself . . . “Nice!” 😁 L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #654717 25th Jan 2023 9:30pm
DrRob
Good stuff Thumbs Up
A decent independent specialist are worth their weight in gold... Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #654732 25th Jan 2023 10:22pm
Doonhamer
Couldn’t agree more - woukdn’t take the Range Rover to anyone other than Newbury 4x4, I can definitely recommend them. L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #654774 26th Jan 2023 1:45pm
