![]() | Home > Maintenance & Mods (L405) > Jacking up a 2019 L405 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8657 ![]() ![]() ![]() |
You can open a door to stop the suspension from dropping or raising but it won't stop gravity dropping the wheel you are trying to jack...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35720 ![]() ![]() |
same, leave the door/tailgate open.. ... - .- -.
Macpaul Member Since: 26 Jul 2015 Location: SW Surrey Posts: 100 ![]() ![]() |
OK thanks, I'll try the tailgate/door thing tomorrow.
No, as I said, nothing will stop the wheel you are jacking up from dropping when you jack up the fatty, gravity takes over...!!
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1753 ![]() ![]() ![]() |
-or get a higher lift jack! |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1166 ![]() ![]() ![]() |
Is it not possible to trolley jack the car in locked access mode? This way the car is lower. overfinch modified |
I was hoping there was a way of locking the suspension...
There is NO WAY to lock the suspension when you jack it up unless you have an anti gravity machine... |
before you go and bang your head again Pete, this is an extract from the owners manual,
Stan,
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8036 ![]() ![]() ![]() |
Isn't that required for the next steps - removing the spare wheel ![]() I've tried all sorts, opening doors, boot, hazards on etc. and not found it makes any difference. Has anyone actually tried & measured a difference ? |
Does anyone know why it should not be jacked in low mode> I,m sure I have seen a Youtube video jacking the car in low mode.
Low mode... high mode, makes no difference to how high you have to jack it, on low made you just jack it more... Pete
