![]() | Home > Technical (L322) > OBD Port / IID tool issues |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
you have spoken to the experts and have theirs views on the problem...
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
I have had this problem previously it is caused by the IID tool having thinner pins than most other readers. They are in spec but at the thinnest end of the specifications.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3864 ![]() ![]() ![]() |
I would not mess with the OBD pins for fear of breaking the socket, … much safer to buy a cheap OBD extension lead off eBay and plug the iid into that.
good suggestion Mike |
kyrantaylor Member Since: 31 Mar 2022 Location: North Yorkshire Posts: 29 ![]() ![]() ![]() |
Have just bought an icarsoft tool - that worked in resetting air suspension fault.
Harlz Member Since: 07 Jul 2025 Location: Hunter Valley Posts: 2 ![]() ![]() ![]() |
@kyrantaylor did you end up having any luck? I'm in the exact same situation. Gap IID tool is not connecting with the car and the LR3.0 carsoft tool only resets but can't interact with the modules (just saying 'an error occurred' when trying to actuate things. |
