Home > Maintenance & Mods (L322) > Simple under bonnet remote start |
Gary Williams Member Since: 17 Jan 2017 Location: Essex Posts: 48 |
Sorry. that is the glow plug system |
19th Jan 2023 5:09pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1364 |
Sorry, but isn't it a bit more complex than that - ie the car is immobilised, so the fuel pump won't run, neither will the PCM for fuel injection etc. I'm fairly confident it wouldn't be a case of running the starter motor.
19th Jan 2023 7:17pm |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 151 |
it will. i did that when ecu refused to start with button. Just modify starter relay in black box to have button on it. If you first press start button to switch power on engine will start. |
19th Jan 2023 8:10pm |
Hi All,
20th Jan 2023 11:08am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1274 |
Tank level when engine dies? Always in the bottom or even when full of fuel? |
20th Jan 2023 11:25am |
Hi Dingg1,
22nd Jan 2023 4:20pm |
Does the 2004 L322 TD6 even have a starter relay to energise the starter solenoid on the starter motor itself? I've looked through RAVE and found references to Engine bay relay box (P125a) and the starter relay (RL16) but where is the starter relay? I can't find one.
22nd Jan 2023 4:24pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Get a weatherproof pushbutton and either extend out of the electrical box or mount on the side, use that to trigger a 30A relay which you can wire across the heavy supply terminal and the output to the starter solenoid - much easier than trying to break into the relay board and decipher the connections. |
22nd Jan 2023 5:47pm |
relay is close to ecu in big black box. |
22nd Jan 2023 6:09pm |
Hi Guys,
23rd Jan 2023 12:07am |
