|  | Home > Technical (L405) > FBH working but no heat |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764      |
 Morning folks
|  22nd Jan 2023 12:45pm |
| Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 798      | The FBH will shut down if the battery is low. MY23 D350 HSE
|  22nd Jan 2023 1:23pm |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764      | Thx Phil
|  22nd Jan 2023 1:50pm |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764      | Thx Phoenix
|  22nd Jan 2023 2:33pm |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631    | It would depend upon how warm the ambient temperature sensor thinks it is. If the FBH failed to fire, (IIRC) it would retry twice then shutdown with a hard DTC and locked out, the combustion fan certainly wouldn't continue for over 15 mins after that.
|  22nd Jan 2023 4:34pm |
|  22nd Jan 2023 5:49pm |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631    | Also check the actual values of the temperature sensors - might give a clue, or at least confirm they are reading accurately. | ||
|  22nd Jan 2023 5:53pm |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764      | Right - not sure if this is going to be of any use but IID reported the following
|  23rd Jan 2023 5:04pm |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631    | Well if the water pump isn't running, that would explain it - I'm fairly sure the FBH would/should fail to start if there is a detectable fault with it's circulation pump.
|  23rd Jan 2023 6:04pm |
| Posting Rules
