Home > Maintenance & Mods (L322) > Electrical Gremlins.. Any help please!
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Hi all
So the fun starts!
2004 TD6. Working on it all weekend with boot and doors open, the battery went virtually flat (not enough to start it). I jumped started it and got it under the carport and put on trickle charge.
Done this a million times with no issues.
Car started straight away, but have inherited a few issues.
Radio screen is black and wont play
Indicators outside work, but dont flash on dash.
Brake lights come on when ignition off
Heater air flow lights flicker and fade
When keys out the "P" red light and the suspension lights are on faint.
I ran Icarsoft and wiped all faults but all it seems to have fixed is the brake lights now go off with the ignition.
Have searched and read a similar experience with advice of "Remove fuse 2" and unplug and replug towing module?
Anyone point me as to where these are? Worth a go as MOT tomorow!!!
Cheers
Tel
. Accept, some days your the pigeon, some days your the statue!
Post #654583 24th Jan 2023 1:42pm
Just try a battery reset, disconnect, fully charge the battery then reconnect, turn steering to both locks.. see what happens... Thumbs Up Pete
Post #654585 24th Jan 2023 2:28pm
Boydonegood
Tried buddy.. No change.. Only thing i didnt do, was touch the leads together, but ive heard as its early BMW it wont do anything?
Currently sitting on driveway for last 45 mins with heater blowing on full incase its damp, cold?
Issue only started after the weekend that i changed back bushes with the doors and tailgate open all day Accept, some days your the pigeon, some days your the statue!
Post #654595 24th Jan 2023 2:53pm
Boydonegood
Ok
So car been running with heater on full for 45 mins.. House mate has just rung and said everything is back working again..
Maybe bit of cold and damp from the weekend?
Guessing only a temporary fix, but at least i have half a chance with MOT tomorow now, until i can find a perm fix Accept, some days your the pigeon, some days your the statue!
Post #654596 24th Jan 2023 3:01pm
Boydonegood
As a side note fella. I see you have gone to L405 now? This is my plan for 6 months time.. can i drop you a PM to discuss sometime?
Cheers
Tel Accept, some days your the pigeon, some days your the statue!
Post #654597 24th Jan 2023 3:02pm
Please do...
I had a similar list of errors after I drowned fatty offroader in that Welsh river, most from the BECM which leaned how to swim... check for damp under the passenger seat... Seeing as you didn't mention water I plumed for battery voltage....Thumbs Up Pete
Post #654598 24th Jan 2023 3:07pm
Boydonegood
Top man
Car isnt damp inside, but i did have boot open all day on 2 of the coldest days while i changed bushes!
Just got to work out how to dry it out/ warm it all up inside
Will deffo drop you a mail.. Only changing mine as Khan expanding the ULEZ Zone! Accept, some days your the pigeon, some days your the statue!
Post #654603 24th Jan 2023 3:24pm
