Home > Technical (L322) > Restricted performance and lots of fault codes |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1348 |
There's no picture attached. Also, not sure why you're reaching redline? Even when towing and accelerating fairly hard, mine rarely goes above 3,000rpm.
24th Jan 2023 1:11pm |
nickjowen Member Since: 06 Jan 2023 Location: Bournemouth Posts: 8 |
Sorry I forgot to upload.
24th Jan 2023 1:45pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4231 |
Read the diagnostic codes? I'd not set foot in my L322 without my GAP IID Bluetooth. Guessing game otherwise.
24th Jan 2023 2:35pm |
24th Jan 2023 3:54pm |
24th Jan 2023 3:56pm |
Apologies, I am new to this forum so I have only just worked out how to add the photos of my codes. |
24th Jan 2023 3:57pm |
Loads of info on the common P040D code (Exhaust manifold temperature sensor on passengers side, UK) but it won’t cause the RP. It can affect DPF regen (allegedly) and there is a diy guide on how to change the sensor in the Wiki area of this forum. I’ll let you peruse and decide if you get a specialist to do it...like I did
24th Jan 2023 8:20pm |
You can also download the workshop manual off the Wiki which has a chapter on Diagnostic Trouble Codes (DTC) 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
24th Jan 2023 8:22pm |
Thank you DrRob, I drive through Cadnam to work so I will look that garage up. I prefer to do the work myself but I did not have the knowledge to know where to start with all the codes. |
24th Jan 2023 8:55pm |
Usually a lot cheaper in the long run to take it to someone who really knows these inside and out.... 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
24th Jan 2023 9:34pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
if you are ok with the spanners with the exception of the P0040 code i would be inspecting all the induction hoses for loose connections, improper fitting and cracks. if you dont have the equipment it would be worth a garage running a smoke test. Manly due to this not happening until you redline.
25th Jan 2023 8:42am |
Update - My restricted performance issue is fixed. I spent yesterday afternoon stripping down the inlet plenum, cleaning it all including map sensor, butterfly etc and replacing the four rubber hoses. It now runs perfectly and seems to be a lot more responsive.
6th Feb 2023 11:51am |
Were the hoses split?
6th Feb 2023 6:42pm |
The front right one had been replaced with a silicone one, but not very well as there was soot alround the perimeter. The rest were original and not showing any signs leaking but I replaced them all with silicone. Cost me a grand total of £13 for 300mm and I just used a jubilee clip to cut 4 lengths at 55mm. Good result. |
6th Feb 2023 9:18pm |
