Home > Maintenance & Mods (L322) > turbos down...
Page 2 of 3 <123>
ergobyte
France 2012 Range Rover Vogue 4.4 V8 Java Black
hermm,
now that you're pointing to it in those terms, it may be a bit too much. Whistle
My indy is maybe a bit enthusiastic with my wallet Confused
he said the engine had to come out to change the turbos. "it needs some intelligence to undestand you may not have enough"
Post #654909 27th Jan 2023 7:23pm
JayGee
You don't need new turbo's - you need a new mechanic Wink 2012 TDV8 Vogue (L322)
Post #654913 27th Jan 2023 7:31pm
ergobyte
Post #654916 27th Jan 2023 7:59pm
Phoenix
I'd agree with that, there doesn't at this stage seem to be anything other than normal oil usage. If you are at all worried, you can get a cheap boroscope from Amazon or fleabay and poke it down the hose to check for wear or pooling of oil.
Modern turbos are designed to pass oil through the bushings, unlike the older style ones with a hard seal, this is to ensure there is no carbon build-up against the seal which will progressively reduce the lubrication - which was the main causal point of diesel engine turbo failures.
Post #654918 27th Jan 2023 8:12pm
DrRob
You are being ripped off with total and utter rubbish. Everything the others have said is spot on.
Get a new mechanic Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #654921 27th Jan 2023 8:44pm
ergobyte
Alas I agree, but getting my hand on a new independent mechanic that know his way around a 2012 TDV8 is quite hard around these parts.
Remember I drive on the other side of the road here Wink FFRR are not as common as in the UK.
Many thanks to you all
Cheers
Sylvain "it needs some intelligence to undestand you may not have enough"
Post #654946 28th Jan 2023 10:04am
DrRob
Drive to the UK for a short holiday and take it to a specialist nr the south coast Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #654947 28th Jan 2023 10:19am
ergobyte
Yeah, I might just do that.
just needs a bit of planning.
Great Idea Thumbs Up "it needs some intelligence to undestand you may not have enough"
Post #654951 28th Jan 2023 10:44am
JayGee
IME it's not a practical proposition to own one of these without easy access to a specialist. Even I'm struggling with this aspect of ownership living in the capital city of the UK. 2012 TDV8 Vogue (L322)
Post #654953 28th Jan 2023 11:35am
ergobyte
Quote:
"IME it's not a practical proposition to own one of these without easy access to a specialist..."
... and the money to make it happen Exclamation "it needs some intelligence to undestand you may not have enough"
Post #654954 28th Jan 2023 11:50am
DrRob
www.glenrands.co.uk is who I use. 20mins from Portsmouth port Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #654955 28th Jan 2023 12:09pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
What? How the mechanic can say something like that without ensure? We have gravity on the earth, and if you have remarkable oil leakage from turbos, where this oil going at first? Of course on the bottom, in lower point of intake. It takes 10 minutes to ensure.
At first open the lower hoses from intercooler. Depending of how much oil coming out from there, make a desigion. If just couple of drops, forget about it, tight better the intake manifold hoses and continue driving. After apr. one mont check again. If again the same result - everything is ok with your turbos and everything else, just drive, enjoy your car and forget about this issue.
If the oil flow out from the lower hose (100-200g, or maybe even half liter) - only then you have a problem.
And, what about your oil level, is it drops? If not at all, where is the issue? If it drops lets say 0,5-1l/10000km its still ok, normal wear for used diesel engine. If you need to add the oil between service intervals, only then you need to start thinking about where its going.
And even then, its not 100% sure there is a turbochargers fault. Need to make deeper diagnostic, find out where this oil coming from and why...still cant belive that someone just saw couple drops of oil immidietly concluse to death both turboshargers.
Post #654980 28th Jan 2023 5:17pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Sylvan,
go get your car back and enjoy it there is nothing wrong with your turbo's induction system normally has a misting of oil in it as already mentioned. check your oil level and monitor over the next few hundred or thousand KM's if the car is drinking oil you may have an issue if not then no leaking. Mine has 130k miles on it i service it every 6 months and never have to top the oil up. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #654986 28th Jan 2023 5:41pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
If it does not smoke on the over run, its OK. I had an early Classic R/R with a Mazda Perkins 3 litre turbo charged engine in the mid nineties which pushed oil out where ever it could. The firm that did the conversion said it was normal, and the engine would last 400k miles before looking at it. The main reason it pushed oil out was a lack of Waste Gate, and over pressuring the inlet. Luckilly modern engines do not seem to have these problems, except, perhaps the 3.6 tdv8 engine. Landrovers that do not leak oil are not common in my experience, and I have four of them currently.
Post #654999 28th Jan 2023 8:18pm
Phoenix
Jaguar3 makes a good point - if the intercooler has a lot of oil in it (>0.5litre) then you have a problem, if not, get your car back & enjoy.
Post #655010 28th Jan 2023 8:51pm
Page 2 of 3 <123>
