Home > Maintenance & Mods (L322) > Battery Replacement 2011 TDV8 4.4
Page 7 of 7 <1234567
JayGee
Does this help?
 2012 TDV8 Vogue (L322)
Post #653296 11th Jan 2023 4:22pm
SNDa180
Thanks @jaygee, that does.
Out of interest, would anyone know what are the two items circled in yellow?
Thanks
Post #653451 13th Jan 2023 2:55pm
SNDa180
Someone also kindly posted this in another group which may be of interest here.
Anyone versed in what the junction boxes do? Or are they just fuse boxes?
Post #653452 13th Jan 2023 3:00pm
JayGee
I 'think' the box behind contains the big fuses for the starter motor. Just looking at my picture I think I should put an insulator cover on that terminal. 2012 TDV8 Vogue (L322)
Post #653478 13th Jan 2023 5:55pm
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
A = for the BMS
B = Distribution box and very important for all the sussystems to work properly
 SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #653529 14th Jan 2023 9:01am
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Battery replacement
Hi all,
It may be something and nothing but a doubt remains. I fitted a Bosch AGM S5 A13 battery last week from Tayna.com and which arrived next day. There wasn't a venting tube etc. included with the battery though. However the previous battery did in fact have one( Varta) and was also a AGM. Does anyone know if these are no longer required on these later ones or do I need to go back to this job? The relevant photos here all show the venting connecter and tubes?
Cheers Dave
Post #653608 15th Jan 2023 12:32pm
JayGee
If the Bosch doesn't have a vent hole then it doesn't need a vent tube. 2012 TDV8 Vogue (L322)
Post #653644 15th Jan 2023 5:51pm
Nylands
Battery replacement
Well I've checked with the supplier who confirmed that they do not require venting and therefore vent tube etc. isn't supplied.
Good news as already fitted!
Post #653705 16th Jan 2023 10:18am
Richard2113
Many thanks
Thank you to the original poster. A really great tutorial which helped me change my battery with no fuss. I have fitted a Bosch AGM to replace the Land Rover badged Varta. Bought from Tayna batteries who I have used before and recommend - good prices and rapid delivery. 2012 Range Rover L322 Westminster TDV8
Post #654959 28th Jan 2023 1:59pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Thanks for all that usefull information. I have had a bit of luck today, I ordered a new Freelander 2 battery the other day for my daughter, and the supplier said they had a supply issue, would I take a similar battery. I said I would see if it would work, I now have a new super deluxe Rangerover battery!
Post #655005 28th Jan 2023 8:29pm
DrRob
Another video from Sam Bow down . Skip to 14:34
?t=874 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90
Post #655235 31st Jan 2023 11:30am
CaifanSC
United States 2012 Range Rover Autobiography 5.0 SC V8 Epsom Green
Welp...I did my first read of this GREAT thread because my Turtle (Green 2012 US-spec Autobiography) almost made me call the tow truck for the first time. It looks like I have a battery issue and I'm going to have to figure out if it's the battery or a drain. Fortunatelly, I was able to half charge the battery using my Ctek charger and get home.
Reading this post, I had a couple questions. There's a lot of talk about the ECU in the way of changing the battery...but what ECU is that? Is it the main engine ECU? Or what's it for? The corollary question is, why did the ECU lose the fan on the later models? I've yet to find out if I have it, but I've read that several 2012's don't have it...so I assume mine will not. Which made me think....well....I kinda want it Smile.
Great post...I'm going to re-read it soon as my current and very preliminary assessment points to the battery being faulty. I've had the car for well over 4 yrs constantly topping off the AGM battery with the Ctek, so the battery is at least 5+ yrs old. When the car didn't start, I left it charging for 10+ hrs overnight before heading home, and the Ctek charger only moved one light, and it was quite warm to the touch. This is very unusual. We'll see, more diagnostics to come as I enjoy reading these threads. 2012 Range Rover Autobiography
91 BMW 850i 6 speed
94 BMW 850 CSi 6speed
Supercharged Tbirds
Audi S8, Audi V8 Quattro
Post #667054 19th Jun 2023 7:48pm
mcspreader
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Many thanks for the guide. Greatly simplified the task particularly the bonnet service position tip although I would recommend doing this with two of you as you really don't want to drop the bonnet with the rams detached at only one end. I found I was able to leave the ECU connected and haul it forward out of the way after removing the two screws that secure the loom going across the panel ahead of the ECU.
I would add that when I reset the battery in IID I used the following process.
Select 'Service/Test' in Menu.
Select 'BCM-Body Control'
Select 'Battery Replacement'
Follow Requests for input. For me (11MY TDV8) there was no request to set battery type which I have read of elsewhere. Edited to read. Just discovered that's in the CCF although the list in mine is not straightforward with no options that match the S5 A13.
I fitted a Bosch A13 AGM battery which was very reasonably priced from Costco. £177 inc VAT IIRC. This was about 10% less than the 'shelf' price as they had an offer on at the time. 2011c Vogue SE 4.4 Oil Burner
1991 Hilux 2.4d MkIII. Sadly goone due to space and time.
2008 Skoda Octavia Scout
2000 TVR Tuscan 4.0
Loads of crap. Gone
Post #680450 16th Dec 2023 12:25pm
mcspreader
Well I've been playing with the CCF battery type data for my vehicle, an 11MY TDV8.
Firstly The options are for H and T batteries from 5 to 8. also an H8HD.Simply, these are DIN size standards.
H models are 175 deep by 190 tall
T models are 175 deep by 175 tall
The number refers to length with 8 meaning 353mm so an H8 = British 019 or Bosch 013.
However, the car doesn't care what the physical size of the battery is, it's the capacity that matters.
So I decided to chose the standard H8 as that most closely follows the 95Ah 850 CCA.
I do not know whether the CCA refers to EN, DIN or SAE CCA standards but I'm guessing DIN because that is the size standard. UK batteries are almost always quoted in EN values so...
...nope. DIN values are totally different:
https://www.roadpro.co.uk/userfiles/PDFs/p...%20CCA.pdf
My feeling is that they are SAE values because Ford (orginator of the CCF file concept). These are higher than EN values. So the aim is now to set the CCF value to H8HD as the Bosch SAE CCA value is approximately 900A and nearer to the 950A choice than it is to 800A.
I tried to flash the CCF twice but both times reported failure although subsequent reading of the CCF revealed the updated value??? Any hints on the correct incantations gratefully received. 2011c Vogue SE 4.4 Oil Burner
2000 TVR Tuscan 4.0
Loads of crap. Gone
Post #680568 17th Dec 2023 8:06pm
RovingCanary
I have just changed my 2012 4.4 to an AGM battery, after the clicky starter motor issue. Absolute pain of a job, and without the 5 point torx it was hard to get everything tight, so I will get one of these off ebay and refit.
It did not start until I reset the battery, then it started first time.
Quick question, just took for a test drive, and the battery was sitting around 12.5v, rather than the 14.5-14.7v you would think if it were charging. Would this mean I have knocked something loose (an earth?), or could it just be the ECU is learning the battery before charging it?
Post #683985 26th Jan 2024 5:22pm
