Home > Technical (L322) > Front Right Lower Wing Bracket
IKB42
Hi,
I have a 2007 3.6 TDV8 which is in need of a new bracket to hold the lower half of the front wing in place, this is the closing panel below the side vents which also has the front mud flap attached to it, apologies if I'm not using the correct terms
This panel came off along with the mud flap whilst trying to remove the wheel arch liner, unfortunately the metal bracket the section bolts onto disintegrated as the clips tore it off the side of the car it was so rusty, I am on the hunt for a new one as MOT time is looming and I can't find it in any of the usual part catalogues
Post #655208 31st Jan 2023 1:12am
Last one i bought was like £20 or £30 quid, new from JLR Thumbs Up
Post #655210 31st Jan 2023 1:35am
IKB42
Promising, do you have a link or part number I can use?
Post #655224 31st Jan 2023 9:01am
JCW
VUB503920
https://parts.jaguarlandroverclassic.com/v...parts.html
This is a kit for both sides - if one side is falling apart with rust, the other is likely the same. Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #655227 31st Jan 2023 9:41am
