![]() | Home > Technical (L322) > Euro 6 retrofit? Will it be possible? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
The wise Mayor Khan's ULEZ down here in London has declared war on Euro 5 diesels as many of you will already know. I live inside the zone and, whilst I have a resident's discount, that will be removed in October 2021 next year.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8756 ![]() ![]() ![]() |
I expect it will be like the LPG cars a few years ago, a big thing about if you had LPG you could get free congestion charge but the only vehicles in the scheme were ones converted at the factory when made, all retrofits were excluded...
Thanks Pete.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
Move outside the zone??? Seams perfectly reasonable to me sir |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
TIC ? However,.only short term solution as more & more LA's join the scams to remove more money from the road users wallets. Coming to a town or city near you soon - Bristol, Oxford, Cambridge, Birmingham, Manchester........ 2003 Range Rover Vogue TD6 |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 200 ![]() ![]() ![]() |
Just thought it was worthwhile reinvigorating this thread, particularly with the imminence of the expanded ULEZ and the inevitable rollout of many more ‘clean air zones’ across the UK and Europe in particular. I would love to keep my L322 4.4TDV8 on the road for a very long time to come so I am hopeful that a solution can be found to reduce emissions to Euro 6 levels.
I spoke to Cybrand. The cost of the kit is one thing. It's the additional cost of getting type approval (emissions) which in their case they just justified based on multiple unit sales. I guess if enough of us got a group buy then maybe.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1517 ![]() ![]() |
Are these kits going to also lock out the car when the tank is empty ? .... the number of times I get into the work vehicles and its moaning that it'll refuse to start in counting down mileage just makes me think I'd hate that in my own car.
Short answer - yes they have to give you a countdown to non-start if there is a detected or perceived fault in the SCR system to comply with EU adopted regs.. 8/10 times it's a downstream NOx sensor issue. |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1031 ![]() ![]() |
Tfl do not accept modified vehicles, if its not type approved from the factory they wont accept it.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2621 ![]() ![]() |
TfL do accept modified vehicles if they’re approved by the Clean Vehicle Retrofit Accreditation Scheme.
OK, mute point. They accept them but there are not any available.
montyjohn Member Since: 07 Feb 2023 Location: London Posts: 19 ![]() ![]() |
Not only this, but Khan is looking into using the ULEZ cameras to start charging all cars a daily charge, even if your car is ULEZ compliant. You won't own your own vehicle soon will you? WILL YOU? 2000 P38 4.0 HSE auto - RHD - just needs a little love. |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1480 ![]() ![]() |
Someone needs to clip this guys wings............. ![]() ![]() 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
