Home > In Car Electronics (L322) > LCM
TerryT-J
Wales 2005 Range Rover Vogue Td6 Java Black
LCM
After connecting the battery back up after charging following lay up since Christmas, the passenger side main beam came on, followed by all rear lights except for the left hand indicator. I turned on the ignition and started the engine, all lights went out but the indicators and hazard lights would not work. After a few seconds, all indicators started to flash by themselves at a very slow rate, about once every five seconds. I'm assuming the LCM is knackered. Is anyone able to confirm please. It's supposed to be going to it's new owner - my Aunt!
Post #584693 21st Feb 2021 2:50pm
Could be some damp or corrosion in the LCM. Not difficult to get out, in behind the lower A pillar trim, by where your right foot goes. You can get the LCM apart and give it a good clean with contact cleaner and a toothbrush, and/or give it some time in the airing cupboard. See if that helps. .
Post #584695 21st Feb 2021 3:38pm
TerryT-J
Thanks Joe90 I'll give that a try. It's just Sod's Law! My aunt was supposed to have it last Sunday when all was fine but weather called it off, so it probably would have gone anyway!!
Post #584716 21st Feb 2021 6:00pm
GUMBALLER
Does a replacement LCM need coding?
Post #655620 4th Feb 2023 10:06pm
Phoenix
Absolutely! - it holds the backup odometer reading and VIN record, if not coded correctly or the data is at variance with the IPK, it'll force the manipulation point on the IPK.
IIRC, the LCM is a 'suck, blow' configuration rather than just a 'code to vehicle'
Post #655623 4th Feb 2023 10:19pm
GUMBALLER
Thank you
Post #655628 4th Feb 2023 10:27pm
GUMBALLER
Thank you very much
Post #655629 4th Feb 2023 10:27pm
Phoenix
No worries, it's a very underestimated core module, probably because it's designation makes it seem so benign.
Post #655630 4th Feb 2023 10:30pm
