Home > Technical (L322) > Battery flat and Emergency key won’t unlock the door
Grundey2
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Firstly, apologies if there is a post covering this, I’m struggling to find one.
My alternator has packed in and I’ve been charging my battery each week till the alternator is replaced in another week. I went out to put it on charge today and the battery is completely flat so the central locking won’t work. I tried both keys incase it was a flat fob.
I wasn’t too worried knowing there is an emergency key so I went to unlock the car with the emergency key.
The key turns the lock 90 degrees clockwise but it still isn’t unlocking the car.
I’ve tried lubricating the lock incase it was a ceased cable or something and tried leaving it but still can’t get into the car.
Please can anyone help me with what i should try next
I need to get into the car so I can get it to the garage for the alternator to be replaced.
Many Thanks, James
Post #655841 6th Feb 2023 7:00pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Do you have a tow bar fitted? Can usually connect a charger via the electrics that should let you in. Alternatively need to access starter motor and connect via the main electric feed to the solenoid. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #655858 6th Feb 2023 8:48pm
Grundey2
I don’t have any tow at electrics.
Where is the starter motor located?
Post #655860 6th Feb 2023 8:54pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
have you tried putting power through the side wing repeater new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #655866 6th Feb 2023 9:23pm
Grundey2
No, do I just pop the indicator out and connect live to one and neutral to the other?
Does it matter which is live?
Post #655867 6th Feb 2023 9:39pm
oggy
the way i should do it is to pop the repeater out and expose both wires connect the earth wire from the doner battery to a good earth on the vehicle that leaves the positive live to deal with touching one of the bare wires with the live from doner battery . have your remote handy to press new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #655868 6th Feb 2023 10:05pm
Grundey2
Thanks for the advice. Does it matter which wire I connect the live too? Will I do any damage if I get the wrong one?
I’ll be giving this a go in the morning 👍
Post #655870 6th Feb 2023 11:03pm
V8 Bob
On a 4.4 tdv8 the starter is accessed from behind the drivers
https://www.fullfatrr.com/forum/topic31909.html
Hope this helps if the indicator trick doesn’t work 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #655874 7th Feb 2023 12:02am
Uhhhh YEAH don't get the + & - the wrong way around for christ's sake... Shocked
Side repeater will have an obvious - wire which will be black... Thumbs Up
Post #655879 7th Feb 2023 1:21am
p38arover
Australia
The OP Mentioned the emergency key. Doesn’t the 2010 MY have a conventional key to use in the lock? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #655884 7th Feb 2023 4:33am
oggy
just read the post stating that the black is - neg new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #655887 7th Feb 2023 9:55am
Grundey2
I tried the repeater but it didn’t work.
I could hear it energise a relay in the engine bay but it still wouldn’t unlock
Post #655929 7th Feb 2023 3:03pm
oggy
okay James bit more work is involved this way but get to the alternate and energize the battery from their new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #655931 7th Feb 2023 3:18pm
Grundey2
Am I right in thinking it’s OS wheel off, liner out and keep going till you find either the starter or Alternator?
Post #655938 7th Feb 2023 3:40pm
oggy
what is the engine model James if you are going in the wheel side and liner out the bonnet cable runs behind the liner on o/s I have seen a vid showing someone giving the outer cable a good pull and the bonnet opened . if not might need to remove the engine cover and get underneath to get at the alternator
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #655939 7th Feb 2023 3:51pm
