Home > My Range Rover > Post Pandemic Full Fat
johnlivingston
Wales 2012 Range Rover Vogue SE TDV8 Orkney Grey
With the changes to working practices since the pandemic, my need for fuel efficiency and reliability has reduced significantly - so I have bought a Range Rover Wink
Having spent over 15 years in a succession of 5 series tourings the FFRR feels like quite a departure
Post #655968 7th Feb 2023 9:24pm
johnlivingston
Taking it into Landranger Deeside on Thursday for a once over to determine whether or not it is a lemon.
With full service history and 94k on a TDV8 I am optimistic that it is good - but getting an expert opinion feels like the prudent move. From there I intend to get oil changed in engine, gearbox, and diffs as a preventative measure.
Niggles so far are a blocked near side screen washer, blocked rear screen washer, a rear wiper blade that barely touches the screen, and a missing wheel brace (replacement ordered from eBay)
Post #655972 7th Feb 2023 9:34pm
dhallworth
Welcome along Smile That seems a perfectly logical way of justifying a Range Rover!
The rear screen washer not working is likely to be the one way valve in the tailgate that’s causing your problem. A lot of people just remove it but it then takes forever to get screen wash to the rear screen so I always replace them.
Easy to tell if it is though, pop the plastic trim off the inside at the top of the tailgate and you’ll see the valve in the rubber tube, pull it off on the body side of it and operate the pump and you’ll see water pour out. Smile
For your rear wiper, turn the wiper on and with it in mid sweep open the top tailgate. This should stop the wiper so that you can change the blade. Whilst it’s mid screen, soak the pivot point on the arm with something along the lines of PlusGas and work the arm back and forth and it should free it off enough to allow it to start moving freely and rest on the glass properly. Might as well fit a new wiper blade at the same time.
Hope this helps Thumbs Up
Post #655989 7th Feb 2023 11:50pm
johnlivingston
Many thanks David - I’ll be sorting that at the weekend 2012 (L322) 4.4TDV8 Vogue SE, Orkney Grey
Post #655997 8th Feb 2023 6:45am
johnlivingston
Hmmm???
So I had found some oil on my drive and then took it into Neil at Landranger Deeside who showed me that the bell housing and subframe are dripping in oil Surprised Surprised
The dealer will be coming to collect it on Monday
Hoping that it is just the oil cooler issue however we’ll see 2012 (L322) 4.4TDV8 Vogue SE, Orkney Grey
Post #656160 9th Feb 2023 10:59pm
knwatkins
That's a bit of bad luck. Hopefully they'll get it sorted for you. Lovely looking L322. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #656161 9th Feb 2023 11:09pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Why not book it in with Cam-tec Craig he is your neck of woods Thumbs Up 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #656162 9th Feb 2023 11:10pm
DrRob
Oil cooler is "routine maintenance" on a sub 100K motor if it's not been done already. I've not heard of one yet that's not needed one Thumbs Up
Insist they change the whole assembly and NOT just the gaskets. They have been known to warp and a new gasket will not fix it!
Nice motor Very Happy Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #656176 10th Feb 2023 8:31am
johnlivingston
Thanks Guys - and yes my understanding is the oil cooler leak is when not if
Some concern that it is something more insidious and keen to exploit my consumer rights if need be (still inside 30days since purchase) but would rather hang on to it.
Already got the L322 bug though Bow down 2012 (L322) 4.4TDV8 Vogue SE, Orkney Grey
Post #656180 10th Feb 2023 8:59am
johnlivingston
So had the full fat for around 2 months now. Had a bunch of issues but remind myself that it is an 11 year old car.
Oil Leak - the dealer sorted out the o-rings. Still trying to decide if the leak has gone now. Am getting drips on the drive but perhaps it is oil that is flowing out of the ‘v’
Gear selector - one day it was 50-50 whether I could get in gear; the following no way at all. After some Googling and reading some posts here I concluded that I needed a selector refurb. Dismantled the center console and sent it to ECUTesting. Received back inside a week and worked fine once refitted. Obvs the car was immobile on my drive for the interim.
Battery - A week after the gear selector was refitted the car broke down. Engine light on the way to work that cleared with the Gap tool. Then wouldn’t start after work. An AA call out and a new battery later then all is well.
Let’s see what happens next.
But crucially I still love it. Particularly for dragging a trailer around my fields. My wife on the other hand is lobbying for it go - no chance Smile 2012 (L322) 4.4TDV8 Vogue SE, Orkney Grey
Post #662470 21st Apr 2023 8:30pm
