Home > Maintenance & Mods (L322) > 4.4 tdv8l322 Thermostat housing water outlet non availablity
Trantorman
United Kingdom 2017 Range Rover Vogue SE SDV8 Aleutian Silver
I have a leaking thermostat housing Which I have had on the two items on back order for weeks, I am now being told 6 months lead time, does anyone know of any other sources other than Landrover for these parts, part numbers below
Connection - Wat LR022690
Connection - Water Outlet LR110459LR
Thanks
Post #656215 10th Feb 2023 5:26pm
JayGee
There are severe parts shortages at the moment and according to what I was told it's going to get worse. My advice would be to see if someone can mend the existing part like I just did.
This is the connector to the bleed valve ( made from pitifully thin plastic that gets brittle with heat and age and even designed wrongly with regards to the hose grip) but repairs to other broken plastic parts are possible depending on what has failed. 2012 TDV8 Vogue (L322)
Post #656224 10th Feb 2023 6:31pm
google the part numbers, you might find someone that has stock.. ... - .- -.
Post #656226 10th Feb 2023 6:53pm
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
Is this the item you need? 2016 4.4 diesel
Post #656232 10th Feb 2023 7:25pm
Trantorman
Morning. I have tried multiple suppliers, who take the prefer and the payment then revert to advise there not in stock.
These are the parts.
Post #656266 11th Feb 2023 10:24am
JayGee
Where is it leaking from? 2012 TDV8 Vogue (L322)
Post #656267 11th Feb 2023 10:37am
Tdtj
Okay sorry my bad
Just got the same part number on my bit so thought was been helpful 2016 4.4 diesel
Post #656268 11th Feb 2023 10:38am
JayGee
This shows the 2 parts joined together ( you were lucky being able to separate yours BTW as the bolts had seized in the brass thread inserts on mine ) 2012 TDV8 Vogue (L322)
Post #656269 11th Feb 2023 10:46am
JayGee
Tdtj wrote:
Okay sorry my bad
It is the same upper part 2012 TDV8 Vogue (L322)
Post #656270 11th Feb 2023 10:47am
Tdtj
Thanks jaygee
I bought mine purely and simply for the one tube that goes to the top hose but you can’t buy it separately so ended up with what I have and robbed it
I bought mine from maltings 4x4 2016 4.4 diesel
Post #656271 11th Feb 2023 10:53am
kevinp
Have you tried doing a search for the Ford part numbers stamped on it?
Post #656272 11th Feb 2023 10:55am
Trantorman
Thanks all for the support, as has been said on here, the bolts fuse in the housing and it all crumbles and falls apart, mine is weeping, but its only a matter of time before it fails, its te same part on the 405 and they seem to fail more often, I am told, i got no where with Ford or trying to find the parts, so currently just monitoring the coolant and its not loosing much, but I need to source the parts. so I will keep looking.
Post #656305 11th Feb 2023 7:45pm
JayGee
So yours is still on the car? 2012 TDV8 Vogue (L322)
Post #656306 11th Feb 2023 8:00pm
Trantorman
Yes mine is still in the car.
Post #656322 12th Feb 2023 9:31am
JayGee
Where exactly is it leaking from? 2012 TDV8 Vogue (L322)
Post #656329 12th Feb 2023 11:17am
