Home > Maintenance & Mods (L405) > Slow intermittent change of 1st 2nd 3rd gears when cold |
M11buc Member Since: 06 May 2019 Location: Newcastle upon Tyne Posts: 37 |
I also have found this. Ok when hot but 1st gear when cold first setting off very light throttle, jerks into gear. I have also changed auto box oil. Made no difference. I have read you can reset gearbox data/ settings, not done this as heard when others have done this it has made made thing worse. Mine also has no fault codes stored for auto box and no warnings come on dash.I only noticed it starting to do this around 2 months ago, before then it was as smooth as silk.
10th Feb 2023 8:11pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 293 |
In all honesty Im starting to wish I never bought this car I much preferred the L322 all I’m hearing is issue after issue online about this model why put a chocolate gearbox into an off-road vehicle AGAIN I would of thought it would of improved dramatically since L322 as it had its fair share of problems as we all know… I’m hoping I can get this issue rectified in some way if anyone knows anything about this gearbox issue!
10th Feb 2023 9:50pm |
