Home > Maintenance & Mods (L405) > Rear pads advice
fisha
Reason the rears wear out so fast is that they do a significant amount of the braking. The car stability control will bias the rear brakes as much as it reasonably can when braking in a straight line as it keeps the car stable from the rear… (think like throwing an anchor out the back to stop will keep it in a straight line ), it will also reduce the grip requirement on the front tyre under braking leaving more for steering control grip at the front.
I u seed to think that cause rears wrote so fast they were woefully under sized, but it’s more that they are worked the hardest. V8 or else ...
Post #656380 12th Feb 2023 7:54pm
Phoenix
caymanblack wrote:
What is the recommended RBP ? Is it best just to get from the Duckworths? I see pld uses EBC anyone uses others?
Personally I'd use genuine, the price differential isn't that great per 1000 miles and the composition is correct for the braking effort required. Aftermarket pads & discs are like aftermarket anything, they meet the minimum requirements, maybe a bit more, but nothing like the performance of the OEM kit.
Post #656381 12th Feb 2023 7:54pm
Gremlin500
@Phoenix:
I acknowledge your much respected knowledge & experience Bow down Bow down Bow down
I am a specialist engineer in braking systems for the last 30 years, and there is very much smoke & mirrors and quite a bit of BS in the industry. Truth be told, there is very little variance in the CoF of REPUTABLE manufacturers* friction linings in the less exotic materials (organic friction). So yes, go for genuine OEM. Otherwise, aftermarket can be a bit of a lottery, with a LOT of Asian fake products abounding on major internet sales sites, as Craig has mentioned several times.
There are a million armchair experts out there, and a lot of dubious claims from aftermarket friction suppliers, we can only hope that the vehicle manufacturers are not duped by their own supply chains, which is always a risk when dealing with these countries.
Anything other than genuine OEM is likely a greater risk, however you may be lucky and find a good product.
Sorry, that didn’t really help, did it? Embarassed
* e.g. JURID, Miba, Ferodo, Mintex, Federal-Mogul. V6 Vogue - “Less is More” - less to go wrong!
Post #656415 13th Feb 2023 12:31am
caymanblack
Phoenix, Gremlin as usual great advice, thank you. Thumbs Up overfinch modified
Post #656434 13th Feb 2023 10:15am
