Home > In Car Electronics (L405) > Apple Car Play on 2017 model
Jay Porsche
United Kingdom 2017 Range Rover Vogue SE TDV6 Fuji White
Hi All,
I have apple car play on my model but it needs to be plugged in to the phone, its not bluetooth enabled.
Ive had it working twice in about 20 tries.
Ive replaced the lead with a genuine apple one but that hasn't fixed the intermittent connecting problems.
Does anyone have any suggestions please?
Thanks in advance.
Post #656590 14th Feb 2023 2:39pm
Gremlin500
Hi Jay, I have this on my MY2017 and it only works with a cable, but reliably.
(Bluetooth not possible, I think)
Did you try another iPhone in case it’s a phone issue?
Is the car entertainment software updated to the latest version?
After that, dirty socket? “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #656592 14th Feb 2023 2:47pm
Jay Porsche
Thanks Gremlin. Have tried all of those and still no joy, even cleaned the fluff out of my port and the car. Just need to try another phone to rule out mine being the problem. It has worked so it should be ok, cant figure it out.
Post #656612 14th Feb 2023 4:54pm
Gremlin500
“ even cleaned the fluff out of my port and the car.”
-that bit made me snigger a bit! Shocked Laughing Laughing
If I even dare mention battery voltage, I’ll be shot at dawn by an unruly FFRR mob, so I’m afraid I can’t help further Shocked
Hope someone cleverer than me comes along soon Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #656615 14th Feb 2023 5:04pm
memzy88
Mine works very reliably via the cable. Never had issue.
I have also bought this CPLAY2air adapter which added the wireless car play functionality. Its works ok most of the time but not as reliable as the cable.
https://cplay2air.com/en-gb
Does your phone charges when you connect the cable every time and just the car play doesn't come up? If it doesn't charge i would think the media unit or the usb ports are not working properly. 2017 Range Rover SDV6 AB
2021 Aston Martin DBS superleggera
2017 Aston Martin DB11 V12 - Sold
2021 Tesla Model 3 Long Range - Sold
2014 Range Rover SDV8 - Sold
2014 Bentley Continental GT Speed - Onyx Black - Sold
Post #656620 14th Feb 2023 5:25pm
Jay Porsche
It works fine when I plug it in to charge, Sometimes have to wobble the cable.
It recognises the phone for Land Rover Apps and connects to that perfectly. Then it says I have to disconnect from the App to use Apple car play so I say ok and then it searches for a while then it says disconnected and then it goes back to the main menu.
I will try my wife's phone and see if hers connects ok.
Post #656627 14th Feb 2023 5:59pm
Chalky
It will only work with a cable, even my 2021 MY has to be plugged in!
The software on late 2017 and especially the earliest 2018 facelift cars had a lot of problems with ACP so if I were you I'd get your dealer to check it out. It probably needs an update which I doubt your car is compatible with as a SOTA upload. All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #656636 14th Feb 2023 7:32pm
Jay Porsche
Thanks Chalky. Im all out of ideas now. So will try your suggestion.
I tried my wifes I phone and it connected straight away.
But when I tried to reconnect it, same problem again!
Post #656744 15th Feb 2023 3:38pm
Chalky
Am I right in assuming you have the latest update on your iPhones (16.3)? If so then I would bet that the ACP in you car's Incontrol is not compatible. I'd call your dealer and ask for the latest update.
Hope you get it sorted, it's very frustrating when the tech doesn't work!! All LR cars from 1984
Post #656750 15th Feb 2023 3:59pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
I must say that, since the latest ICTP update (S22A_22.32.4-928505), the connection is much improved. I am using a Cplay2air wireless adapter and I would say it fails only once in 50-60 connections. In that case, only a system reboot (car closed for 10 minutes) reenables the CarPlay connection... Still, it's acceptable, given the crappy intel atom NUC (Next Unit of Computing) mini PC that strives to keep the infotainment alive... 2019 Vogue P400e
Post #656851 16th Feb 2023 3:12pm
Jay Porsche
Thanks to all for your comments.
I am pleased to report that an update of the software on my iPhone seems to have fixed the problem!
It connects and works every time now!
Thanks so much.
Post #657189 20th Feb 2023 9:46am
Chalky
Thumbs Up Thumbs Up All LR cars from 1984
Post #657202 20th Feb 2023 11:55am
CSK942
Hi all,
I have a Dec 17 Vogue, I'm wondering if I have have Apple carplay ? How would I know if I have Apple Carplay ? Not sure I've seen the option for it anywhere but prolly looking in the wrong place Sad
Post #670810 9th Aug 2023 11:07am
Chalky
Plug your iPhone into the USB and if you have it, it will come up on the screen All LR cars from 1984
Post #670811 9th Aug 2023 11:15am
CSK942
Hi Chalky and thanks for that.
Tried it over the weekemd but it doesn't look like I have it unfortunately Sad
Post #671148 14th Aug 2023 10:17am
