Home > Technical (L405) > immobiliser vs cabin preheat
Arch Stanton
I'm contemplating having an immobiliser fitted but just had. thought; the cabin is preheated off the app by starting the engine, if I have an immobiliser, will this prevent the cabin preheat from starting? Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black.
Post #656646 14th Feb 2023 9:13pm
Kot
I can confirm with the Ghost 2, that I now cant use the cabin pre-heat with engine start etc from the IC app.
But at least the car is where I leave it Rolling with laughter
However if you use the G2 phone app (I dont), if your car is within range (BT) a few meters, G2 is disabled so suspect it would work. 2018 SE SDV8 4.4 Byron Blue
Post #656698 15th Feb 2023 9:55am
Martin2
Your profile says you have an AB, so you would use the remote to pre-heat the car (or set a time in the infotainment) which doesn’t start the engine, so I can’t see it being an issue with an immobiliser. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #656699 15th Feb 2023 9:58am
Arch Stanton
Hi Kot, I shall look into the Ghost (using the Ghost2 app)
Martin, I do have an AB but it doesnt have a separate remote for the pre heater, I use the Incontrol app for it and it does start the main engine.
I'll set the infotainment to preheat on a timer, so does that start a separate pre heat motor or start the main engine? Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black.
Post #656707 15th Feb 2023 10:32am
Martin2
You can get a remote for the pre-heater, I would.
In the meantime, yes, setting the timer in the car will only switch on the FBH, not the engine. MY23 Panamera E-Hybrid
Post #656716 15th Feb 2023 11:53am
Arch Stanton
fantastic, that gives me some options.
Cheers gents Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black.
Post #656803 15th Feb 2023 8:53pm
6885leem
There's a great video on YT re Ghost2 - check out SASMobile. They've done a SVR where it locks out the gearbox rather than the engine so the remote start still works.
Post #656874 16th Feb 2023 7:18pm
Kot
Originally there were issues using the transmission lock but think this may have been resolved.
https://www.rrsport.co.uk/forum/post609245.html 2018 SE SDV8 4.4 Byron Blue
Post #656906 16th Feb 2023 11:38pm
Arch Stanton
I forgot about the timed climate function on the internal screens, that may be my solution especially if I can get it to operate off a remote. How can I tell if mine is compatible with a remote? Buy one and try it o can I find out of a spec sheet/look of built in kit? Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black.
Post #657093 18th Feb 2023 10:01pm
Ask your dealer to check? I did and they ordered in two & programmed them for less than £50... Thumbs Up
Post #657105 19th Feb 2023 1:27am
Arch Stanton
fabulous, thank you sir, I shall try that avenue Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black.
Post #657106 19th Feb 2023 1:34am
