Home > Technical (L405) > Rear Wiper
Dannymc
Scotland 2014 Range Rover Vogue TDV6 Santorini Black
Rear Wiper
Hello,
I was wondering if anyone had come across an issue with the rear wiper where it works intermittently, after a few wipes it just stops on the window then a while after will work again, I was going to purchase a used one online from a breakers but I’m not so sure it will solve the issue?
Post #656888 16th Feb 2023 9:35pm
West Yorks V8
Hi
I’m sure this is the correct way of working, to allow the drips and excess wash to run off the rear screen. Cool Range Rover 4.4 SDV8 Autobiography
Land Rover Freelander 2 SD4
Range Rover P38 4.6
Range Rover Classic LSE 4.2 x 2
Range Rover Classic 3.9
Range Rover Classic 3.5
Post #656907 17th Feb 2023 1:08am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I asked a similar question a while back shortly after I got my L405.
It seems the standard process of the rear wipe on intermittent mode is to wipe a couple of times to start with then a single wipe one way and park..... then a single wipe the other way and park (and so on)
I was used to the double wipe and park in the 'home' position but this has changed.
(See my provious post here)
HTH Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #656915 17th Feb 2023 10:20am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Thanks guys but this is a change of behaviour for mine and not normal. I'm thinking a new motor. Did the change on my 322 so how hard can it be on the 405. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #656929 17th Feb 2023 12:54pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
https://drive.google.com/file/d/1aSE85XAUn...sp=sharing
From the Wiki, download and find the procedure. Doubtful it is hard. Likely time consuming. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #656953 17th Feb 2023 4:25pm
Dannymc
Thanks everyone, for mine the wiper basically stops in the middle of the rear window, doesn’t move again for a while then wipes a few times and sticks again. I think I’m going to just buy another motor and see how if it fixes the issue.
Post #657257 20th Feb 2023 9:12pm
