Home > Maintenance & Mods (L322) > Coolant system flush
David p
United Kingdom 2011 Range Rover SE TDV8 Alaska White
Hello, I’m just about to do a coolant flush on my 2011 tdv8 and wondered which radiator hose would be best to remove as I can’t find a petcock
Many thanks
David
Post #657128 19th Feb 2023 1:46pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Does the radiator not have the drain tap Low down on the OS? If not then take the expansion tank hose off & let it drain from there Thumbs Up
Post #657147 19th Feb 2023 7:08pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
you will need to remove the bottom radiator hose to drain new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #657148 19th Feb 2023 7:13pm
