Home > Technical (L405) > Front End Hum
Dannymc
Scotland 2014 Range Rover Vogue TDV6 Santorini Black
Front End Hum
When I push the accelerator I hear a kind of hum of whine, which stops when I take my food off, (while in motion) is this normal? I recently got the tracking done and I couldn’t remember hearing this before then? I could only get the front done as the guy said on the 2014 model the rear wheels can’t be aligned.!
Post #657272 20th Feb 2023 11:15pm
From the W/M, toe can be adjusted at the rear...
TIE ARM
The tie arm is pressed steel with both ends having a bush pressed into an
integral housing.
The inner bush locates between brackets on the subframe and is secured
with a special eccentric bolt, washer and nut. This allows for the adjustment
of the rear wheel toe. Rotation of the bolt moves the eccentric head within
a recessed slot in the bracket, allowing the toe to be adjusted within the set
limits. The outer bush attaches to the wheel knuckle. Pete
-Click here for Thread-
Post #657275 20th Feb 2023 11:30pm
Dannymc
Thank you very much mate, that’s really in-depth and helpful
Post #657282 21st Feb 2023 12:43am
