![]() | Home > Maintenance & Mods (L322) > Upper tailgate rattle |
Floopy Member Since: 28 Jan 2023 Location: Devon Posts: 98 ![]() ![]() |
Just another normal day in the life of an L322 owner. ![]() 2008 L322 Vogue SE 4.2 S/C |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Last time I suggested a 'ride in the boot area' she wasn't very happy |
If you can't see any movement of the tailgate / lock, check that the spoiler has not become loose. |
Glibbs Member Since: 18 Aug 2019 Location: West Somerset Posts: 114 ![]() ![]() ![]() |
Thanks - will do. Range Rover 4.2 SC
ash27 Member Since: 23 Jun 2020 Location: Hertfordshire Posts: 47 ![]() ![]() ![]() |
Let us know if you find the fix, mine rattles and I still need to sort it out as I cannot see anything obvious that is loose. 07 4.2 Supercharged
I will of course. Range Rover 4.2 SC
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 397 ![]() ![]() ![]() |
i had this a couple of weeks back when you shut the upper tailgate you could get hold of it and lift it up slightly when in the shut lock position found out that the locking pin in the lower tailgate the hole plate was loose and moving around so needed to tighten up the 2 bolts that hold the hole plate in place. there are 2 Torx bolts. but you have to make up a tool to get to them as the gap is very small to get in and get them done up once done upper tailgate was being held firm again and no more rattles. new vehicle purchase
Many thanks - I'll give that a go tomorrow and let you know how I get on. Range Rover 4.2 SC
