Home > General > L322 width mirrors folded
EOD Steve
United Kingdom 2012 Range Rover Vogue TDV8 Sumatra Black
Hi all,
Would someone be so kind and measure in CM the width of your car with the mirrors folded please? I am in the process of getting quotes for a new garage door so that a 322 will fit, at a considerable cost.
Wouldn’t want to spend money unnecessarily!
Thanks
Steve
Post #657359 21st Feb 2023 6:14pm
mjdronfield
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #657379 21st Feb 2023 8:01pm
EOD Steve
Thanks for your message.
My access space is 204cm.........
Post #657381 21st Feb 2023 8:03pm
mjdronfield
Bloody hell… 3mm spare each side then….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #657395 21st Feb 2023 9:38pm
EOD Steve
New garage door then £££££ Sad
Post #657419 22nd Feb 2023 11:18am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
One question, How do you get out then?.
Post #657422 22nd Feb 2023 11:27am
EOD Steve
The current door is fixed such that it takes up some of the access width. A new style door fitted behind the access recess will increase the overall access width or 'drive through' space to 2300mm, an increase of 260mm, allowing much wider vehicles access, including FFRR!!!!!!!!
Steve
Post #657426 22nd Feb 2023 11:36am
EOD Steve
PS............the inside space is way over 3m wide....
Post #657427 22nd Feb 2023 11:37am
Highroller
No problem then. I wouldn't like to push a Rangie in & out of the garage Rolling with laughter
Post #657431 22nd Feb 2023 11:58am
Floopy
Put some ramps down and drive through the opening on a slight angle? 2006 L322 Vogue SE 4.2 S/C (no longer owned)
2008 L322 Vogue SE 4.2 S/C
Post #657435 22nd Feb 2023 12:22pm
