Home > Maintenance & Mods (L405) > steering column gaiter
Page 3 of 4 <1234>
caymanblack
Looks as new Gremlin , well done. overfinch modified
Post #657471 22nd Feb 2023 6:54pm
Gremlin500
Thanks @Caymanblack Embarassed
Everyone loves a bargain! Very Happy
I’ve done well lately, what with my £50 Osram D3S Nightbreakers too! Very Happy
Fingers crossed this will get her sailing through the MOT in a couple of weeks, there was an advisory last MOT of the flexy brake hoses (slight corrosion) but these were all replaced during my “mega” Brembo 6-pot brake upgrade last Summer. V6 Vogue - “Less is More” - less to go wrong!
Post #657481 22nd Feb 2023 8:50pm
Gremlin500
Well, that was easy! Well under an hour from start to tools put away and celebratory cup of coffee Very Happy
Old one out:
New one in:
I did raise the suspension to off road height to give maximum extension of the telescopic steering column, so then had to stand on a platform to get a better reach down into the engine bay. The most difficult part was not dropping the bolts! Laughing
A cheap fix! Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #657746 25th Feb 2023 4:30pm
Gremlin500
I’m possibly risking a bit of ridicule posting this, but here goes anyway: Embarassed Very Happy
I’ve decided to use THIS as preventive mainenance to keep the rubber in nice flexible condition, (as an ex-caravanner I used to use this regularly on cassette toilet seals to stop them perishing, and it kept them like new for years).
Just takes a bit of Dutch courage to visit a caravan shop Laughing
No need to lecture about the dangers of perished rubbers…..
Rolling with laughter Rolling with laughter Rolling with laughter V6 Vogue - “Less is More” - less to go wrong!
Post #657748 25th Feb 2023 4:42pm
caymanblack
Gremlin, the sort of owner you want to buy your Range Rover from. Bow down overfinch modified
Post #657763 25th Feb 2023 5:44pm
Gremlin500
@Caymanblack, thanks for the compliment Embarassed
It’s good to keep on top of things…….
Having cut off the old boot to have a post mortem, I see now why you can’t just change the bellows, even if one was available: The coupling parts inside are max 55mm diameter, and the holes in the ends of the rubber are only both 25mm in a 3mm groove) so they must vulcanize the two halves of the bellows together over the complete assembled joint, I can’t see any other way it could be done. Effectively a “ship in a bottle” situation. Censored
Suppose a 2-part bellows would work, fitted from either end. V6 Vogue - “Less is More” - less to go wrong!
Post #657782 25th Feb 2023 6:47pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I inspected mine while replacing the engine mounts last night. My steering boot is ripped too.
Time to see if my extended warranty covers it or if I have to search eBay for a replacement… Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #657882 26th Feb 2023 7:27pm
Gremlin500
@Bora20:
Good luck! Be very careful, nearly all the ones on eBay are already split, I was lucky.
If it helps, the RR Sport has an identical part, used parts dealers /dismantlers are another option.
I have an as yet unproven theory that using “comfort access” all the time contributes to the swift demise of this part, as the angle of the UJ increases as the suspension lowers, and the joint straightens more as the height is increased.
Having dissected the rubber boot, it seems the convoluted parts are very thin (1mm) and not robust enough to cope with the frequent angle changes. My original boot made in 2016 seems to be inferior in quality to the replacement made in 2017.
I therefore reccommend disabling comfort access, (especially if you have deployable sidesteps, it’s not really necessary if you are of anything like normal stature, including females) to reduce wear & tear. This feature also causes wear and tear failures in the steering wheel lift/lower mechanism, as reported by PowerfulUK, so there are two possible reasons not to enable it. Crying or Very sad
Does the RRSport have comfort access as an option? The 2017 used boot above looks brand new. Whistle
EDIT: RR Sport of course has air suspension and comfort access - but being lower, maybe owners don’t use it as much? V6 Vogue - “Less is More” - less to go wrong!
Post #657928 26th Feb 2023 11:22pm
Bora20
Thanks. The search is on tomorrow after I find out if extended warranty will cover it.
I like comfort access. It helps my parents and kids. I can live with buying a new part if that’s what it takes. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #657931 26th Feb 2023 11:52pm
knwatkins
Well done Gremlin. Looks like a simple enough fix 👍 Shame the boot isn't available as a separate part. Maybe over time it may be available as a 2-part assembly. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #658043 28th Feb 2023 8:53am
i had mine done under our UK extended warranty so i imagine yours should cover the work..
i also doubt whether the access mode , auto or manual would affect this part...i rarely use that mode and the previous owner was a tall chap so he didnt either.. ... - .- -.
Post #658055 28th Feb 2023 10:31am
Gremlin500
Warranty is the best option if you have it, £187.67 plus an hours labour say £135 at MD is well over £300 all in Shocked V6 Vogue - “Less is More” - less to go wrong!
Post #658071 28th Feb 2023 11:49am
Gremlin500
Well, I’m ressurecting this thread, because I think I may have found a way to refurb these, but I need a few to take to bits and play with. If anyone has one they took off in reasonable nick, please PM me and I’ll be glad to pay a few quid plus shipping, thanks guys. Bow down V6 Vogue - “Less is More” - less to go wrong!
Post #701261 1st Oct 2024 10:11pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Earlier this year when my 4.4 SDV8 engine was out for its rebuild I noticed my UJ gaiter was split so it was the ideal time to replace it. Balking at the price of the complete assembly I managed to source a replacement gaiter, which was very good quality and is still as good as new - much more compliant than the original.
Just do a search on Ebay for DA3689, several companies selling them.
HTH L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #701264 1st Oct 2024 11:48pm
Gremlin500
Wow! Shocked £45 just for the rubber is a lot!
I’d be looking at £90 for the complete unit with new rubber and two new Inbus+ bolts.
But I need some old ones with split rubbers to start with……… Bow down V6 Vogue - “Less is More” - less to go wrong!
Post #701279 2nd Oct 2024 11:08am
Page 3 of 4 <1234>
