![]() | Home > Technical (L322) > L322 4.4 TD 2011 Thermostat Housing |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3403
Where is it cracked? My garage managed to source the lower part before supplies ran out but the upper part is non existent...... 2012 TDV8 Vogue (L322) |
| Alphabatim Member Since: 20 Apr 2021 Location: Anglesey Posts: 5
Have just discovered that the part is not called a Thermostat Housing but is
The top part with the temp sensor ? 2012 TDV8 Vogue (L322) |
Hi JayGee... Thank you for getting back .The crack is in the lower piece ... any idea where they managed to source it? |
Where is the crack exactly?
Its the bottom part .. it was cracked underneath and broke off when removing it ...if I can get a bottom part it would do ... |
like this?
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
Try Gentlemen of Salvage I have used them for hard to find bits for my p38 and a diff for my l322 |
If you are going for a used part get one from a later L405 SDV8 as the plastic will still be in good condition. 2012 TDV8 Vogue (L322) |
As J said get the newest you can and order the new part but at least it will get you going till it arrives I have had to do it a couple of times |
Thank you for replying and yes that is the issue exactly… I will follow up on both your suggestions… like the idea of used one as temporary solution…have called a number of dealers in Ireland but same problem.. will try France Next! |
| All times are GMT |
