![]() | Home > Maintenance & Mods (L322) > OAT Antifreeze |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 190 ![]() ![]() ![]() |
Just after a bit of advice and owners experience on anti freeze, will soon be doing a coolant change on my 2010 3.6 TDV8 and was going to go for OAT concentrate from a well know motoring shop. Its got the pink stuff in already so guessing its OAT in there currently, was going to drain and flush and then add OAT 50/50 mix.
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 ![]() ![]() ![]() |
Thanks for the advice much appreciated
Don't flush or mix with tap water - especially if 'hard' water, coolant systems should be flushed either with pre-mixed coolant or de-ionised water, dilution should also be with de-ionised water.
Notyalc Member Since: 23 Dec 2022 Location: Northumberland Posts: 7 ![]() |
Agreed, always use de ionised water. Easily available in 20L containers. |
