Home > Technical (L322) > Restricted performance |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3069 |
Get a HIGH pressure smoke test done. That will show you your leak - could be split inlet manifold (they are known for it) |
26th Feb 2023 11:10pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
As above, smoke test to see if you have a split hose/plenum or manifold.
27th Feb 2023 8:47am |
MitchMcd Member Since: 26 Feb 2023 Location: Scotland Posts: 11 |
Thanks for the replies will check the hoses etc at the weekend looks like it’s all the original hoses still on it only started doing it a couple of weeks ago as drove it on the motorway when I bought it and didn’t do it cheers Mitch |
27th Feb 2023 8:26pm |
Maximtaylor Member Since: 19 Feb 2023 Location: Winchester Posts: 1 |
My 2012 Westminster was doing the same thing a few weeks ago. I got the sensor replaced, which was the egt sensor in the manifold, but the restricted performance message came back. The PO40D code didn’t come back though
27th Feb 2023 8:43pm |
General Member Since: 22 Jun 2020 Location: UK Posts: 15 |
I've stolen Ninos picture to help explain.
28th Feb 2023 8:14pm |
Hi thanks for the help I had a quick look at the 4 rubber hoses that go to the plenum only managed to get one off as it was getting dark I’m planning to remove and check all above mentioned on Saturday I’ll check those hoses too general as maybe Iv knocked something as I serviced it the other week just after I got it thanks agin Mitch |
1st Mar 2023 9:47am |
3rd Mar 2023 10:33pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3690 |
MAP is manifold absolute pressure..
4th Mar 2023 8:38am |
https://www.fullfatrr.com/forum/topic47735.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
4th Mar 2023 10:06am |
4th Mar 2023 10:46am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2770 |
Also check the MAF sensors on the air filter box outlets. The error may refer to a mismatch between the actual air mass measured by them and the calculated airmass from pressure (MAP), temp and RPM. 2012 TDV8 Vogue (L322) |
4th Mar 2023 11:13am |
5th Mar 2023 4:23pm |
Nice. As a matter of interest have you checked that your cross over valve for turbos at base of radiator has been upgraded from the early “nut” design? You can just about see it if you peer down the radiator area off centre right. Plenty of info on here. Search CSOV
5th Mar 2023 6:45pm |
Hi mate I haven’t checked that is that done under recall? |
5th Mar 2023 7:16pm |
