![]() | Home > Technical (L322) > Connection - water outlet parts needed |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3297 ![]() ![]() ![]() |
They are out of stock everywhere - what part has broken as repairs are possible ( and likley your only option ) 2012 TDV8 Vogue (L322) |
Alinton Member Since: 05 Aug 2019 Location: Kilkenny Posts: 56 ![]() ![]() ![]() |
Both cracked when being removed to find an oil leak. How are they repaired? Epoxy resin maybe? |
If it's the outlet and inlet connectors/ tubes they can be sleeved with aluminium and glued with rubber impregnated cyanoacrylate but if the body of the units are cracked I'd not rely on glue alone. Unfortunately the plastic on these has become weak and brittle with age. The other option is to source used parts from newer L405 SDV8 engines which are less likley to have age related weakening. 2012 TDV8 Vogue (L322) |
Are the L405 parts directly compatible? |
Yes. 2012 TDV8 Vogue (L322) |
