![]() | Home > General (L405) > SDV6 vs Tdv6 |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 300 ![]() ![]() ![]() |
According to this page the TDV6 is on a par with the SDV6
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 931 ![]() ![]() |
I've had both engines and not much difference, the SDV6 is more "tuned" and although I've never had problems, they say (whoever they might be!!) the SD is more prone to crankshaft issues.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1417 ![]() ![]() |
SDV8 ![]() |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3812 ![]() ![]() |
^ this - if you are spending that much - just have done with it and buy the V8 - it’s not that much more 😊 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1832 ![]() ![]() ![]() |
I’m intrigued by this, as I hitherto never realised there were 2 versions of the ahem, “TTV6D” coexisting at the same time, you learn something every day! |
Gremlin
Thanks Kot,
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
The engines are the same, gents. It is just mapping tweeks.
Steve144 Member Since: 25 Nov 2021 Location: Sussex Posts: 6 ![]() ![]() |
Thanks for the replies.
Having had vehicles with both engines Steve, there is a night and day difference between the V6 and V8 diesel engines in terms of power delivery.
Typical cheapskate JLR, they didn’t even stretch to giving new owners an “SDV6” badge, having spent all the budget on a remap! |
A BIG factor you may not have researched is the V8 gets active roll control. The V6 does not! You may find passengers getting motion sickness in the V6. This I've heard MANY times from customers... Sons/daughters or grandkids...
Hi Criag,
Au contraire, in fact the “Adaptive Dynamics” system on the V8’s IS yet another “what if?”. Complex network of hydraulic pipes with virtually no corrosion protection, running through difficult-to-access areas. It’s not even a what if, its a “when” so in fact a possible reason to avoid the system if your budget doesn’t run to complex repairs, read this: https://www.fullfatrr.com/forum/topic62477.html The V6 engine is much lighter than the V8’s by a significant amount, so the vehicle is not so “nose heavy” kids will chuck up in any car, therefore should never be transported in your lovely FFRR ![]() |
