Home > Off Topic - Other Cars > Range Rover 2017 SPORT SVR L494 sos limited functionality
da3533
United Kingdom 2017 Range Rover SVAutobiography 5.0 SC V8 Fuji White
Hello
I have a Range Rover 2017 SPORT SVR L494.
Today, just got warnings about the 'SOS LIMITED FUNCTIONALITY'
Doing some research, it can be a load of things with the Telematics Control Unit (TCU).
However, the first thing to do is change the back-up batteries.
On some sites, it states the TCU is located above the main screen behind the centre dash? see image below:
How do i get to this? Do i have to remove the cover and remove the main screen, behind it? or?
Thanks
Post #658834 8th Mar 2023 7:44am
Kot
What permanent DTC code do you have? 2018 SE SDV8 4.4 Byron Blue
Post #658835 8th Mar 2023 8:07am
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
You will probably be better off on ;
www.rrs.co.uk
Post #658836 8th Mar 2023 8:08am
da3533
Re: Range Rover 2017 SPORT SVR L494 SOS LIMITED FUNCTIONALIT
Unnecessary quote removed
not sure. before i take it in to get this done at a price, i wanted to change the first easiest thing first which is the batteries....
Post #658837 8th Mar 2023 8:45am
da3533
Post #658838 8th Mar 2023 8:46am
Kot
The first easiest thing to do is do a DTC check 2018 SE SDV8 4.4 Byron Blue
Post #658839 8th Mar 2023 9:36am
da3533
Will do.
Do you know where the module is located?
I dont want another module, its the batteries i want to try first. but I have seen modules for sale while searching for this error code online. I have notices the module title people used were:
2017 RANGE ROVER SPORT L494 REAR LEFT PHONE HOTSPOT TELEMATICS CONTROL MODULE LH #RS050620
REAR LEFT.. i have a RR SPORT SVR 2017 REGISTERED DECEMBER 2017. So looks like the location is Rear Left (c Pillar) and not located where some RR's between the years 2014 to 2016..
Post #658842 8th Mar 2023 9:53am
Kot
No
Do you have a valid Incontrol Remote subscription ?
Do a simple search ie
Decided to pay for the InControl Remote subscription for 24 months at £57.60
How atrange is it that now The Sos works fine and no warning light at all...... how many other people have had to pay for diagnostics and repairs for this function/warning light to not appear when obviously JLR know there is nothing wrong you just have to keep renewing your subscription
https://www.rrsport.co.uk/forum/topic58912...p;start=15 2018 SE SDV8 4.4 Byron Blue
Post #658848 8th Mar 2023 10:25am
da3533
i have never removed the previous owner.. Might have to go in to dealer and get them removed....
thanks. that is a start. When i registered for an account and put in the VIN, it says registered with someone else...
Post #658849 8th Mar 2023 10:33am
da3533
it is a bit silly to subscribe to make it work again, clear the message. Maybe one doesn't want it! Should be able to clear the warning without committing to a 2 yr thing.
Post #658869 8th Mar 2023 5:28pm
da3533
Hello
Got a guy to run diagnostics... it was running a tests and when it got to the Telematics Module, it stated: 'connecting...' but the test had finished 100%....
so looks like it cannot get an error code? Module faulty...?
i have codes of the two first error codes that popped up while testing.
B1412-96 PERMANENT QUIESCENT RELAY BOX - COMPONENT INTERNAL FAULT
P060A-08 INTERMITTENT INTERNAL CONTROL MODULE MONITORING PROCESSOR PERFORMANCE - BUS SIGNAL/MESSAGE FAULTS
U0055-87 INTERMITTENT VEHICLE COMMUNICATION BUS D - MISSING MESSAGE
Also, i took a picture of above the accelerator pedal just to see if the module was there or not.. i noticed, a grey plug unplugged.... what is this, is it supposed to connect to something?
Post #659796 19th Mar 2023 4:06pm
