![]() | Home > Technical (L405) > Locking Issue L405 2014. |
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135 ![]() ![]() ![]() |
Just to clarify, is the double beep the one that goes with the indicator flashes to show it is double locked or the double beep (quieter ones) indicating unable to lock. Chris
Don Henshall Member Since: 25 Sep 2010 Location: Essex Posts: 114 ![]() ![]() ![]() |
The quieter ones. 718 GT4
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 377 ![]() ![]() ![]() |
Failure to central lock is usually caused by doors not shut properly. This could either be a lock slightly out of line or an electronic fault giving a false message that a door is not shut properly.
So something is preventing it locking? Doors/tailgate/bonnet not fully closed? My sport bonnet needed a good slam down even though apparently fully closed otherwise it wouldn't lock. Chris
Ok, after several experiments I believe it’s the tailgate door that is the problem. She has just come back from her annual service and it sounds like it needs some lubrication on the struts or something like that which might be impeding it from fully closing as the lower half is definitely soft closing but the upper part not so.
Mollyhetherington Member Since: 29 Feb 2024 Location: West Yorkshire Posts: 1 ![]() ![]() ![]() |
Mine doing exactly this now. Just wondering if you managed to get to the bottom of it and how to fix please?
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 252 ![]() ![]() ![]() |
I have had this three times. Each time required a new door lock actuator to repair. One door left until I have a full set! Dan. 🇨🇦 2013 L405 5.0 SCV8 |
