![]() | Home > Maintenance & Mods (L405) > 2013 4.4 L405 main battery drain |
Max94L405 Member Since: 27 Jan 2023 Location: Hampshire Posts: 41 ![]() ![]() ![]() |
Hi all,
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135 ![]() ![]() ![]() |
I'm not an expert but as you know I also think I have a problem though not as fast a drain as yours.
Thanks for that!
Did you get anywhere with this? Be interesting to know if there is a common culprit. Chris
It’s going into my LR specialist in a couple of weeks will keep you updated! 🤞🏻 |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 748 ![]() ![]() |
Is this causing any issues on your car Max?
I just have to charge it at least once a week otherwise battery drops bellow 12v and don’t want to start damaging the new battery or other modules in the car. Mine is a 2013 so doesn’t have stop/start luckily! |
12.1V is about the lowest you should let an AGM battery go to avoid damage.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1747 ![]() ![]() ![]() |
Max,
I fitted a brand new battery so can rule that out!
Tailgate operates fine without any issue.
Hmmm, is it draining, or simply just not charging?
It’s draining. I fully charge it to 12.8v. Over a week it will discharge down to 12v.
Mine was doing similar Max, main battery was dropping to around 12 to 12.4v.
