![]() | Home > Technical (L322) > P0046-77 (2F) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493 ![]() ![]() |
Faults shown are normally a symptom and not the cause.
Grundey2 Member Since: 03 Jan 2023 Location: Lincolnshire Posts: 31 ![]() ![]() ![]() |
It a 4.4 TDV8.
Any loss or irregular boost from either turbo? When does it go into restricted performance? E.g heavy acceleration?
It’s really intermittent. I took it for a run to try and diagnose it. I drove it steady, booted it, engine braked and it wouldn’t fault, then steady cruising at 55mph on the dual carriageway and it faulted.
The symptoms are similar to a small split in one of the charge air hoses or a leaking union, are you able to get it smoke tested? - not the usual low pressure smoke test, needs to be around 1.5bar. |
I’ll ring round and see if there is somewhere that can smoke test it.
The two big hoses at the front of the engine bay.
Charge air hoses are anything after the turbos, air intake hoses are anything before them. |
Ok, thanks for all the advice, I’ll strip some more hoses off and inspect them.
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 166 ![]() ![]() ![]() |
Bookmarked this as it is suspiciously similar to the problems my 4.4tdv8 has.
Keep us posted on how you get on with the smoke test, I’d be interested to know what they find |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1360 ![]() ![]() ![]() |
Have you checked if the CSOV for the second turbo moves freely. There is an upgraded part. |
Which is the second turbo, and what is the CSOV? Is it the actuator at the bottom on the near side of the engine bolted through the radiator housing? If so Yes. I had it off and cleaned it up etc when I swapped the alternator, belt and tensioner a couple of weeks ago. |
Sounds like you found it. Charge air shut off valve.
