![]() | Home > Maintenance & Mods (L322) > Do I just hit it with a bigger hammer? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
Trying to get the tow bar off, all looks very simple std LR stuff, box section arm plugging into square socket. Removed the pin and started trying to shift it with a lump hammer - didn't budge.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35828 ![]() ![]() |
a. |
RRRob Member Since: 24 Jul 2010 Location: Bury Posts: 123 ![]() ![]() ![]() |
Try some penetrating fluid or WD40 then
Letsavit has a tree you can pull out. |
I'd go with D.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
He's to scared! ![]() You just need a BFH! |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
you could also put some gentle heat on it. Current: TDV8 (3.6) RRS HSE
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Duck oil or diesel over night.
Mine is also corroded in, I've used penetrating oil, heat, chain round a tree and whilst the tension was on I placed a 20 ton bottle jack between the ball plate and the bar......and it's still seized solid.
Thats what I thought too when I removed mine... the next size up hammer will work.
The "Adjustable" spanner as we call it. Lol |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2074 ![]() ![]() ![]() |
Is it the swan neck or fixed plate?
It's fixed plate, I would like to remove it because I should be able to remove it and I'll need to if I get my hands on the official LR bike rack ![]() When I've got it off I'll grease everthing up so it will slip in and out easily in the future - oh err......... ![]() I'll give it a "proper go" this weekend! Geoff |
Just make sure you don't give your rear bumper a "facelift" with the extra gusto! |
