Home > Maintenance & Mods (L322) > new battery - full size benefits ?
albertocsm
Portugal 2011 Range Rover Vogue 4.4 V8 Zambezi Silver
hi everybody.
just got a diesel 2011 4.4L V8 FFRR!
im currently looking for a battery and i see a lot of recommendations here to go with a 020 AGM like the `Varta - Dynamic AGM H15 (105Ah, 950A)` for example.
that is a somewhat expensive battery when compared with a `Varta G14 (95Ah, 850A)` which i believe would still be in spec.
what would be the benefits of going with the bigger battery?
PS:
sorry if this is a dumb question. i don't really understand a lot of this.
Post #659309 14th Mar 2023 2:19pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Just remember that on the 4.4 fitting a 020 in place of the 019 will require some effort modifying the positive battery connection as it restricts the battery length that can be fitted.
Benefits are greater capacity so will take longer for any drain to flatten the battery. Get the highest CCA/Ah rating you can find.
Fit AGM. They can be discharged deeper and can accept charge rates higher than standard flooded batteries - the charging system is designed to work at around 14.7-14.8V which is acceptable to AGM but which is somewhat higher than the 14.4V charge voltage flooded batteries like for longevity.
Remember the BMS needs to be reset via diagnostics so the charging system knows the battery has been changed. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #659316 14th Mar 2023 2:54pm
Danb_220_2019
Similar modifications as described in this thread will be required to accommodate the added length of a 020 battery:
https://www.fullfatrr.com/forum/topic58066.html 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Post #659319 14th Mar 2023 2:57pm
JayGee
Just get the standard size battery - it works well for normal usage. If you need extra capacity for running extra electrical items fit a 2nd battery in the right side boot space. 2012 TDV8 Vogue (L322)
Post #659326 14th Mar 2023 5:37pm
garyRR
An 020 will fit in a 3.6L pre 2010 but not vehicles 2010 onwards, with the fan and other gubbins in the tray.
019 works fine though, because the later FFRRs are less 'leaky' on battery draw.
019 AGM. Varta, Bosch, Numax, Exide, Powerline are all reputed brands. There's a Powerline in mine at the moment, fitted in 2018 and works fine. 2015 Range Rover Autobiography 4.4 SDV8
Post #659330 14th Mar 2023 6:17pm
If you don't have diagnostics you don't "have" to tell the BMS you have fitted a new battery, it will learn it is new after a sort time... Thumbs Up Pete
-Click here for Thread-
Post #659332 14th Mar 2023 6:45pm
albertocsm
thanks for the input everyone.
i had no ideia a 020 wouldn’t fit out of-the-box on the L322 from 2010 onwards.
Post #659382 14th Mar 2023 10:12pm
Danb_220_2019
I'd love to believe that, but my 2012 4.4TDV8 when I bought it had recently had a new AGM battery... within a couple of months of my buying it. I was hopeful, but...
I ended up fully charging it off the car with my CTEK (in Recond mode) a few days after I bought the car. I wanted to make sure the FBH was working properly for timed (and remote) climate which had failed the first time I tried it.
Checked the draw alive and asleep - no sign of major quiescent drains like many suffer from and the electronics shutting down as expected.
After charging the battery fully I refitted it and a couple of days later timed climate worked 100%. Drove the car down to Suffolk (280mi, more than long enough to make sure the battery was replenished) and the next day, no FBH - runs for a few minutes then shuts down with a low battery condition (later confirmed with Webasto Thermo Test diagnostics). Sit in the car for 10mins and the 'battery low' warning appears on the screen. Drove home 280mi a couple of days later.
Decided just to ignore it for a few weeks and then probably buy a new battery. During that time I tried timed climate, manual startup, checked the FBH was actually working properly, ran diagnostics, checked live data for charging voltage and alternator output. The battery showed all signs of being unable to hold charge or a charging system fault - but I could see the charging system was working and with the battery charged off the car it seemed to hold charge fine.
Was on the point of buying a new AGM battery, but before that I thought I'd try another full charge off the car, then refit, reset the BMS, and see what happens.
That was a couple of weeks ago and the timed climate has worked perfectly every time I've used it (which has been daily for most of that time). I've been able to use manual climate start on a couple of occasions, and haven't seen 'battery low' since. I haven't been doing long journeys in that time either.
All I can say is that since I charged that battery (which I was thinking was probably shot) and reset the BMS, things that didn't work previously now do. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Post #659388 14th Mar 2023 10:56pm
