![]() | Home > Technical (L405) > Coolant leak info required |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1525 ![]() ![]() |
Do you have rear climate control ?
fenair Member Since: 01 Sep 2021 Location: Norfolk Posts: 47 ![]() ![]() ![]() |
Top man, yes i do... it kind of came to me ths mornig that would be the only logical reason for coolant there, my intial thoughts was that there may have been some diesel warming system , hence why i posted , but then in teh light of day the penney dropped, im going to get under it tomorrow and investigate futher..
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8790 ![]() ![]() ![]() |
IIRC Replacing the pipes with genuine is a huge job, apparently a lot has to be removed to replace the original pipe, some have just used a rubber pipe and rerouted it to save all the dismantling... |
Thanks Pete, I suspect that would be the case, hopefully the diameter will be a size we use for AC hard lines,then I can do a repair section rather than replace, I will do a post if possible.
