Home > Maintenance & Mods (L322) > 4.4v8 fan roaring permanently
Geoff West
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Hello, i have three strange problems that happened simultaneously with a battery replacement.
First thing I noticed was viscous fan roaring all the time. I had fan replaced with a factory unit but made no difference.
Second was Outside Temp sensor which began reading -40c, or sometimes -2c or -3c i had the sensor replaced (in the wing mirror). Made no difference, so forked out and fitted a good used wing mirror. Made no difference.
Third problem - when I started car morning after battery fitted, it started as normal and revved as normal, but as soon as I put it in gear, the revs drop back and the throttle is completely unresponsive for at least 20 secs and then suddenly responds. If I let the engine warm up the problem is nowhere near as bad, but some throttle delay can sometimes be noticed. Only significant fault codes were MAF, now replaced but made no difference, and a throttle position reference (which I forget(. Strangest thing is NO warning kights in dash
Any thoughts, help or advice would be greatly appreciated, many thanks, Geoff
Post #660030 22nd Mar 2023 1:56pm
First off, as you have found, don't just change things when a fault code appears, 95% of the time it is not the item that has failed but the fault system itself....
You have classic voltage issues, they like to have a charged battery and get upset with lower voltage...
Disconnect the battery, give it a full overnight charge then reconnect and take it from there....
Also, fill out your vehicle details in your profile so we know which model etc you have... Thumbs Up Pete
-Click here for Thread-
Post #660032 22nd Mar 2023 2:52pm
Geoff West
Thanks Hayland I'll try that (and update my profile ta)
Post #660043 22nd Mar 2023 4:22pm
garyRR
Please stop using your current garage and replacing parts willy nilly - they clearly like to cash in (sorry, but it's true).
As Haylands has suggested, I'd start with the battery. Then I'd move onto the causes, not the symptoms of fault codes. Very rare for a 4.4 TDV8 to develop any of the issues you have described. 2015 Range Rover Autobiography 4.4 SDV8
Post #660057 22nd Mar 2023 7:34pm
Geoff West
The car always goes to an independent LR specialist, and they are very good. Problem is they are in such demand that there's a 10 week wait for an appointment. So in the meantime I ordered the fan and wing mirror on Ebay and was convinced that would cure the problem, but it's obviously some other problem, likely electrical.
The battery is new and well charged, and I've tried leaving it disconnected overnight but to no avail. The fact that no throttle response when engine/transmission is cold, but ok when it's warm should point to something but i can't think what.
Post #660071 22nd Mar 2023 9:50pm
garyRR
Sounds like it could be poorly fitted multiplugs after previous repairs?
Unlikely, but also possible to be the PCM. 2015 Range Rover Autobiography 4.4 SDV8
Post #660072 22nd Mar 2023 9:54pm
GraemeS
Australia
I would check all power and earth connections in the vicinity of the battery.
Post #660074 22nd Mar 2023 10:05pm
Geoff West
Thanks, I'll check the multiplugs and connections around the battery area but tbh I'm not hopeful. The lack of throttle response when selecting 'Drive', but only when cold, has me completely baffled. It's a pain waiting five minutes for engine/transmission to warm up before you can go anywhere, especially when you're running late! Smile
When (if!) it eventually gets sorted I'll be sure to post details - it seems so unusual that I'm sure the reasons would be of interest to other owners.
Post #660076 22nd Mar 2023 10:27pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Try doing a Hard reset & see if that brings back the original settings.
Post #660103 23rd Mar 2023 11:08am
Geoff West
Thanks Highlander, tried that but no difference
Post #660110 23rd Mar 2023 12:25pm
JayGee
It would be wise to invest in a GAP IID tool so you can do proper diagnostics. It will pay for itself very quickly and can be sold for a near new price if you move on from JLR ownership. Most here wouldn't contemplate L322 ownership without one... 2012 TDV8 Vogue (L322)
Post #660112 23rd Mar 2023 12:31pm
Geoff West
Thanks Jaygee, i've been thinking that. Would a generic one do the job, or would it have to specific to RR? Any recommendations ( at a reasonable price)?
Post #660113 23rd Mar 2023 12:50pm
JayGee
The GAP IID bluetooth is by a large margin the preferred device and will do a lot more than a generic code reader.
https://www.fullfatrr.com/forum/topic65903.html 2012 TDV8 Vogue (L322)
Post #660114 23rd Mar 2023 12:59pm
Geoff West
Thank you, appreciated
Post #660115 23rd Mar 2023 1:27pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
With regard to Cooling Fans, I found that a lot of Jaguar and Landrover parts interchange, and in the Ford era, Ford parts. Key Modules have Volvo stamps for instance. I had, some years ago a full speed fan on a Jaguar V12, and found, upon dismantling the fan motors and resistor pack that the resistor pack was heavily corroded, and fell apart. So its worth disconnecting the fan multiplug, and check the resistances and whether you are continuously drawing full power. A stuck Air Con relay can do the same, but its also worth doing a diagnostics check just in case, but often faults at the front of any vehicle are corrosion somewhere.
Post #660116 23rd Mar 2023 1:33pm
