Home > Technical (L405) > KVM & Keys - Washed key!
TJH1985
So it looks like I decided to deep clean one of the key's Censored having dried it out in some silica gel desiccant, close inspection has revealed some pretty extensive corrosion to the IC and board including damaged leg's and track - -so its dead. Big Cry
I know it requires a new KVM, Key and SDD programming or a auto locksmith to "virginise" the KVM which tbh I don't fancy.
Has anyone been through this process? The dealer has quoted a not insignificant amount of money for a KVM, Key and programming when it goes in for it's service next month - but I am considering my options, especially if it results in getting more usable keys.
Has anyone used second hand key's in the process? I wouldn't mind buying 1 x new key and 1 x Used key so I have 3 in total in case it happens again.
Also can the IID Tool program a new KVM rather than using SDD?
There also seem's to be a vast array of key part numbers the latest being LR087661 but all of the 5 button remotes look the same. If anyone has purchased them, which did you end up with?
Thanks,
Tom MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry!
Previously Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #658671 6th Mar 2023 7:14pm
andygts
The locksmith doesn't virginise the KVM.
When I had mine done they had some kit to solder directly onto the board and go directly to the memory, the key's not in my possession were deleted and he added me a new second key. All done in the back of his van on my drive + cutting a new emergency blade.
It honestly took him longer to get my KVM out as it's stuck behind the rear climate stuff in the boot on an L405. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #658923 9th Mar 2023 8:53am
TJH1985
That’s interesting, one of the locksmiths I spoke to said that approach for MY16 > wouldn’t enable the transponder for the emergency start (held against the console) but would work for all of the keyless stuff, unless I used a non genuine key. Assume that’s not true? MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry!
Post #658982 9th Mar 2023 7:37pm
andygts
I'd have a ring round, it will only be the more talented locksmiths that tackle stuff like this. It's not an easy plug the laptop in and run some software kind of job, it's a bit more involved. Current
Previous
Post #659035 10th Mar 2023 12:13pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Hi, I programmed my Freelander 2 keys, bought on ebay for £17 with the Autel Maxi AP200 app on my phone with the Landrover add on software. It was a £57 app. with a £28 add on and I bought the dongle from an Autel agent. Its done on the car so no laptop needed.
https://www.autelstore.co.uk/wholesale/aut...anner.html
Post #659057 10th Mar 2023 7:45pm
TJH1985
Unfortunately it's not as simple on the newer car's due to LR locking the KVM.
I spoke to a few locksmiths who suggested various method's some involving aftermarket keys that they could clone the old key onto, some suggested they would solder onto and directly writing a new genuine key to the KVM but this may result in it not working as an emergency key although Andy’s experience contradicts that!
In the end mainly thanks to the wait to get it into the dealership, and taking the car on holiday soon, I ended up doing it myself.
If anyones interested:
I used a Jaguar KVM (Part# J9C16073) at £95 and then a new JLR Key (Part# LR060128) at £110 followed by SDD (Pat @ GAP confirmed IID couldn’t do it) to update the KVM software (FK72-14C104-AH > FK72-14C104-AR) and then program the original and new keys onto the car, which was around a 20minute process many automated ignition cycles and ending with verification of the keys. There was allot of reassuring verification including placing the keys around the gear selector and then SDD attempting to turn the ignition on automatically etc.
The reason for using the wrong part numbers was purely down to cost, the OEM part numbers seem to just be different revision's and they were the cheapest new parts I could find.
All in all a expensive lesson learnt, I now have 3 key's just incase I do it again Rolling with laughter
Thanks for the replies both Thumbs Up MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry!
Post #660077 22nd Mar 2023 10:50pm
garyRR
This is posted in the L322 forum.
Good locksmiths can do the job for £250. Have a Google search and you'll find some.
The main dealer will give a load of nonsense that the car needs a new KVM plus keys (and quote about £1,000).
The IID tool can also be used for programming a new key on the L322. Keys with blank remotes can be bought online for c.£100. 2015 Range Rover Autobiography 4.4 SDV8
Post #660131 23rd Mar 2023 3:44pm
TJH1985
Yeah sorry this is a L405, and I am sure it was originally in the L405 forum how odd! MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry!
Post #660148 23rd Mar 2023 6:19pm
Hanwellfields
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Zermatt Silver
Spot on. I had to get some new keys, suited and coded, for the little Abarth. I asked the locksmith about the L322. The lady had just recently recoded one.
Note:The LR dealership in Cheltenham had quoted way north of £1200 and also said the module needed replacing. It seems they are not able/ authorised to reprogram. They have to use a new module as that is LR policy. Current: L322 2011 Zermatt Silver TDV8 Vogue SE, MB GLB AMG35, Renault Clio R200 Cup
Previous: Audi RS4 Avant Nogaro, Audit TT Sline, BMW M3 E92, BMW Z4 3.0i SMG, Macan GTS, Boxster S 986, Touareg V6 TDI
Post #660241 24th Mar 2023 2:37pm
TJH1985
Those MD prices are insane, I’ve just double checked our quote and for a L405 it was £580+Vat.
We had a play with the original module and the dealer SDD software and there was no way to program a locked KVM we even tried to reprogram it as a new module etc. There are loads of sites selling the software dumps to reset them back to factory, but I don’t have the kit for that and neither do I have the kit or patience to solder directly to the board and wanted genuine key’s not clones. All in all I’m happy with the £200 DIY approach that mirrors what a MD would have done.
It also depends if the car has been near a MD to have the software update done that locks them in the first instance? MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry!
Post #660242 24th Mar 2023 2:44pm
Kot
And a useful cheap dtc reader and resetting tool as well 2018 SE SDV8 4.4 Byron Blue
Post #660247 24th Mar 2023 3:35pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Try PD Auto Locksmith, He’s Called Paul and is based in Yorkshire, worth the travel if he can fit you in. He did mine on a 2016, removed the KVM and re flashed it together with new key. He also removed the key that was lost in my case from the KVM, all has been good since. He charged me just over £200 but that was three years ago. Not sure how far he travels but he came out to Stockport to sort mine out. He also specialises in JLR.
Post #660453 27th Mar 2023 9:55am
TJH1985
Thanks for the recommendation, its all good now, sorted it myself Thumbs Up MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry!
Post #660461 27th Mar 2023 11:10am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Hi TJH1985
Just dropped you a PM with regards to this!
Thanks L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #660850 1st Apr 2023 12:25pm
4RRS
Having had a similar scenario when I damaged a key I went down the locksmith route, all I can say is if my experience is the norm then don't!!
I ended up with 2 non genuine keyfobs (never mentioned it before the work was done) and even though I was told the emergency start transponder operates I can categorically confirm that they don't. I was never happy with them and have now decided to order up a new KVM and fobs and programme with SDD myself.
Fortunately I still have my damaged key and the transponder is still operational, this is a minimum requirement when replacing the KVM via SDD, so if you go the non genuine route and then decide to get new keys and KVM and don't have a functional transponder, you've got a problem which involves even more cost. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #661257 6th Apr 2023 9:24pm
