Home > Technical (L322) > Inlet manifold |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Perseverance... standard tools will do it, there is no magic fix, I did use a small air ratchet on mine but a hand ratchet will work, just slower. |
21st Mar 2023 11:41pm |
Rudyard1 Member Since: 15 Nov 2021 Location: Leicestershire Posts: 63 |
I’m thinking - if I loosen all the injector bolts, and inlet manifold bolts, would it just pull straight up and out?
22nd Mar 2023 8:56pm |
Injectors first, they sit in the cylinder head by some distance so you can't 'cheat' them out by lifting with the manifold. Don't be tempted to split the rear one, it'll never work properly, despite what you may read on the internet.... |
22nd Mar 2023 9:05pm |
Thanks for this Phoenix - how much did you have to Jack the engine up? Also these parts - LR019118 - where do they fit?? 2007 Range Rover Vogue 3.6 TDV8 |
24th Mar 2023 1:09pm |
james hester Member Since: 24 Mar 2023 Location: cumbria Posts: 5 |
I'm about to do the same to mine! does anyone have a part number for the injector seat seals?
24th Mar 2023 4:19pm |
Not an excessive amount, the engine mount needs about 50mm of separation from memory, the 'O' rings are to replace the ones on the injector leak-off pipe, the bit that pushes into the injector. Make sure you refit the 'R' clips to the injectors before you put the injectors back in the cylinder head. @James Hester, you'll find a link on one of my posts on the previous page for the injector seals. |
24th Mar 2023 4:37pm |
Nice one thanks for that.
24th Mar 2023 4:58pm |
The profile seal comes with the cover/inlet manifold, as does new fasteners. |
24th Mar 2023 6:20pm |
All replaced and new fuel leak off line in. However it will not start - does anybody have any ideas to next step?
1st Apr 2023 9:03pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 205 |
When I did mine- the engine wouldn’t start for ages- to the point the battery died- assuming everything is connected- it seemed to take a little while to build fuel pressure sufficient enough to start it 2007 TDV8 Vogue SE
6th Apr 2023 8:44pm |
Well being the simpleton that I am, when cranking it over I started to smell diesel…….look underneath to see the oily stuff dripping on to the drive.
7th Apr 2023 7:33am |
Glad you got it sorted!!! 2007 TDV8 Vogue SE
7th Apr 2023 3:05pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 776 |
Good you got it sorted with a positive outcome. I look forward to reading your full write-up with pics 2007 TDV8 VSE
8th Apr 2023 7:35am |
