Home > Technical (L322) > Parking Heater Remote Control
Page 4 of 7 <1234567>
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
axle wrote:
How come so many Censored sell their cars without the remote ? Banging Head
Because it went to an underwritter Whistle
Post #66014 27th May 2011 12:10pm
wiggs
or they sold the remote ..as there about £90 from Land Rover Shocked
Post #66016 27th May 2011 12:12pm
dan_uk_1984
Only the Vogue TD6 has the remote start function as standard I *think*, the HSE or below has the aux heater but no receiver (although was tickable) If it was ticked as an option on the petrol then you got the whole lot.
Post #66023 27th May 2011 12:48pm
stu
funny how this has worked for you axle!! i am going to try mine again tonight. i have a T90 module in the boot and a T91 remote.
maybe either the remote or the module are not working properly.
is there any way of checking these?
if the heater comes on from the touch screen, does that involve the module starting it? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #66027 27th May 2011 1:12pm
wiggs
Are you sure Shocked
FBH = DIESEL
Post #66028 27th May 2011 1:17pm
dan_uk_1984
FBH = DIESEL
Quite sure. Thumbs Up
Post #66030 27th May 2011 1:20pm
wiggs
Shocked
So do you have a seperate diesel tank to run the FBH ?
Post #66034 27th May 2011 1:26pm
dan_uk_1984
It's not unheard of to have a faulty remote, I had one and it took me a while to figure that out - I needed to borrow a known good one to verify a working reciever and a faulty remote.
Nope
Post #66038 27th May 2011 1:44pm
dan_uk_1984
wiggs wrote:
Shocked
Why would a FBH only run on Diesel?
Post #66039 27th May 2011 1:45pm
wiggs
not saying it should ...but i wouldnt want a petrol one sat under my bonnet . Shocked
I was just under the impression that they were all Diesel
Post #66048 27th May 2011 3:25pm
dan_uk_1984
It doesn't just spray fuel all over the engine and chuck a match on Laughing
Both the Diesel & Petrol fueled FBH work in the same way, high pressure fuel is atomised through an injector and ignited (initially) by a glow plug. Then when up to temperature the glow plug is turned off when the flame can sustain itself.
There is a turbine inside to constantly feed oxygen and remove exhaust gasses - much like a jet engine.
Post #66049 27th May 2011 3:30pm
wiggs
Yes ..i understand how they work ....still not keen on a petrol one though
Petrol engines get up to temperature without the need of FBH ...so presumably its just used for pre heat ?
Post #66050 27th May 2011 3:50pm
dan_uk_1984
Then I don't understand why you wouldnt want one? It's not like it's going to catch fire...
It is used for pre-heating and Auxilliary heating if requested (via OBC) Same as the Diesel except doesnt come on automatically at low temps...
Post #66054 27th May 2011 4:16pm
stu
well, my new T90 remote arrived today in the post.... Shocked
it's massive in comparison to the T91!!
anyway, out to the car after work tonight, put new batteries in it, pulled the fuse, pressed the off button, got a red light.
left it all for a minute till i put the cover back on the fuse box, pressed the on button bobs your uncle she only fires up.. Bow down Bow down
i then pressed both buttons together to change LED from red to green and pressed on button again and sure enough the blower and cold air fired up.
i have come to the conclusion then, that either the T91 is not compatible, (it was supposed to be brand new) or it is a duffer.. Sad
can someone actually confirm that they have a T91 remote working with their T90 boot module and secondly, would someone like to try my remote out to see if it is a duffer or not or give me a clue to check another way if it works or not please.?? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #66495 31st May 2011 6:49pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I have the same problem with my T91 remote, it does not seem to work with my 2005 unit. All I get is the red LED flashing whatever I do. I might have to do the same and get a T90 remote. I got the T91 one from the bay, being sold as a newer version, but it looks like it is not compatible, or one of a faulty batch.
Post #67264 6th Jun 2011 5:49pm
