![]() | Home > Technical (L322) > Leaking F/R/H Spring |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35828 ![]() ![]() |
rob, tilemanvogue has just fitted one ,might be worth a pm to him.
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
in my opinion, you should always as good practice change things in pairs. i haven't done it on the FF yet as i haven't had it long enough....(touch wood)
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
i only changed the one on mine as the other side looked well....also i was told it tends to be the drivers side front that goes all the time alltough they didnt have an explination as to why....but all in all a very easy job "RANGEISM WILL NOT BE TOLERATED"
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
Firstly, originals are Delphi.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
There is a company in the US that does the replacement bags so it's a bit cheaper. Have a look round rangerovers.net/forums |
RRRob Member Since: 24 Jul 2010 Location: Bury Posts: 123 ![]() ![]() ![]() |
Thanks for the advice |
tilemanvogue Member Since: 22 May 2011 Location: Aylesbury Posts: 24 ![]() ![]() ![]() |
Hi Rob Where did you order your parts from. I purchased my strut from Island 4x4 cost was 249.99 +vat best price around. My strut was caused by a stone or the like cutting the bag. Only changed drivers side as the other was perfectly ok. Yes easy to replace just had trouble with bolts that connect to hub, they were stuck solid. Discovery 3.9 Range Rover 4.6 HSE 1998 L322 Range Rover Vogue 4.4 2004 |
The maker of the replacement airbag alone is Arnott in Florida. The 2 replacement bags cost $400 or about the same amount as one replacement strut (GBP243) retail. In addition, though, you need to add a minimum of 1 hour to r&r the airbags on the old struts, so to compare you are realistically looking at about GBP175/side with just the Arnott bags (and old shocks) vs. GBP245/side with new OEM struts.
You don't even need to deflate the system to change the struts: drop to access height and then jack the car up. The very small residual pressure - if any - can easily be let out by cracking a line or 2. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
you could go this way and replace with coil springs...
Stan that defeats the object of a RR me thinks.
i suppose it does rob, but for a permanent 'fix' it could be viable... |
it would certainly be cheaper |
Ugh. No, castrating a RR is not the way to go.
Are the rear air spring more "relaible" than the front ? or should I expect them to be giving up the ghost anytime soon ?
