![]() | Home > Technical (L322) > P0046-77 (2F) |
Grundey2 Member Since: 03 Jan 2023 Location: Lincolnshire Posts: 31 ![]() ![]() ![]() |
Yep, fair point.
Looks like I’m making progress.
If you can get an actuator, it will 'just work' in 95% of cases as the position is driven by the measured boost - the other 5% of cases needs a teach-in of the extents.
Thanks, it’s been frustrating to find but glad I’ve finally found the issue.
Just make sure you get the orientation of the actuator rod right, I've seen a remanufactured one that was assembled incorrectly and caused all kinds of problems, I've never seen a repair kit, the extents are stored in the engine control module, not the actuator, if you're replacing the mechanicals, the extents would likely be different anyway due to slight positional variations.
Many Thanks, I’ll keep you posted on progress |
Well, after many phone calls and searching the net I found the right actuator.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1324 ![]() ![]() ![]() |
Hi James, have you got any part numbers for the actuator please? |
There wasn’t a part number on mine, you need the part number of your turbo.
Thankyou. |
