Home > Maintenance & Mods (L322) > What's best to clean grubby boot cover/parcel shelf?
manfrommissenden
2006 Range Rover Vogue Td6 Cairns Blue
Hi,
My cream boot cover/rear parcel shelf is looking pretty grubby so would like to see if I can get it clean, but not sure what with as can't work out what it's made from... looks like a woven material bonded onto the reinforced plastic of the boot cover itself.
Was thinking of just trying upholstery dry cleaning foam (i have some simoniz stuff).
Any experience anyone?
Many thanks
Post #65350 23rd May 2011 10:40am
mzplcg
I had the same issue with a sand coloured one. I used washing powder / hot water mix with a soft brush and also some Vanish. Then I used the wet vac to dry it off. Repeated a couple of times on stubborn stains. Not perfect but a lot better than it was.
Dom
Post #65366 23rd May 2011 12:43pm
supershuttle
Mine is sand as well, this is what I did.
Hit the stains with some agressive stuff, swarfega on anything oily, some autoglym upholstery cleaner on the others - good scrubbing where needed. This left "clean" patches so I put it on garden table and gave it all a good scrub using 1001 and then rinsed with a hosepipe, kept the back dry as possible.
Left it to dry although I had to put it back while it was still damp due to the fact it started raining.
Looks spot on now and none the worse for a good soaking Geoff
Post #65369 23rd May 2011 12:56pm
1001 dry foam a really good scrub and rinsed off with a hose Thumbs Up I now keep it clean by fitting it to the spare bedroom but I have tints so you cant really see in. 2008 MY Supercharged
Post #65395 23rd May 2011 2:54pm
dan_uk_1984
Depending on how grubby your shelf is I have used AutoSmart Brisk Dry Foam very good indeed. It's great for the headlining too as it doesnt over-wet the surface. Smells great too!
Edit, just ran out to the car and cleaned mine:-
Before, with general grime:
IMG_4907 by d86cfv, on Flickr
During:
IMG_4911 by d86cfv, on Flickr
After (most maks have gone, although some left on the very edge):
IMG_4917 by d86cfv, on Flickr
Post #65401 23rd May 2011 3:11pm
manfrommissenden
Gents, thanks very much for the tips.
No massive stains on mine, just 4-5 years of atmospheric pollution - dont think parcel shelf has ever been cleaned.
From your posts looks like a dry carpet/upholstery cleaning foam + elbow grease seems to do the job.
Will have a go and try and post some before and after photos.
Thanks again!
Post #65438 23rd May 2011 5:21pm
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
always use STARDROPS its the UK version of the greeks windex Razz
Post #66042 27th May 2011 2:16pm
jammyk
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
sounds silly but...
With a cream interior i keep baby wipes in the car. These are used very sucessfully in cleaning the parcel shelf. little elbow grease required and drys very quickly!
Post #66855 3rd Jun 2011 11:24am
Vogue
+1, and seats, pants, dashboard, steering wheel, console - oh and babies Cool
and they are cheap 99p for a huge packet - wet wipes are crap and expensive
Post #66859 3rd Jun 2011 11:59am
