![]() | Home > Camping, Caravanning and Holidays > Caravan movers |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364
My Powrtouch AWD movers use to do it as well. I would have to switch them off and back on and then all was well. I've just upgraded them to auto engage ones but haven't had chance to use them yet!!
| Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548
I had this issue everywhere I went. So nothing environmental. Must be something on the caravan. Alarm or router maybe. I have pulled the fuses on both these but the issue remained.
| TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 672
My Powrtouch Auto AWD movers do this very very occasionally, I just let off the button and repress and all is well. Thinking about it mine got allot better after I got a new remote for them as the other failed (lost its range). Mine have two control box's, I always put it down to one loosing the signal for some reason, I swopped the boxes around and the problem didn't follow the box so just chalked it up as one of those things. Like I said it's very occasional and just releasing the button and repressing resolves it. MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry!
I cringe every time I do a tight turn and I see the tyre's trying to part company with the rim. |
It’s not something I need to do a lot but it’s there if needs be. It recommends it’s done on hard surfaces rather than soft ground as it’ll dig its way in. Nice option even if used just to fine tune a position.
| James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 303
Same here, mine did it when the battery was a bit low. It would seem to get out of sync on one side (normally the side moving faster when turning) and drag the roller up the tyre a bit. An on/off would reset it. I can see why you were annoyed if it was happening frequently, especially if you're trying to clear a road. I've sold my caravan now so it's not a worry any more |
I’ve been playing with the new ones. They work on WiFi too via an app but the reach is pretty poor tbh. A bit pointless really but may have been a workaround if the interference was still evident. Tops up its not so all good. |
| Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1211 |
I have the single axle truma on my twin axle it works so far not had a problem except when a wire was loose, Steve at Vanmaster found it.
Hi Alex
I have had Powertouch on two of my other Vanmasters and as you have said they do struggle on the incline and seem to sap the power from the battery, hopefully, the new system will work out better keep us informed on your findings. 2017 SDV8 4.4 silicon silver AB
I’m off to the Cotswolds on Saturday morning, so I get the opportunity to get it out of the drive and onto the back of the car and then obviously into a pitch if it’s not a driveable one, we’ll see how it goes. |
Bit of an issue regarding remote signal but the fitter met me at my pitch and seemed to sort it out. Works a treat now. They seem very gutsy compared to the Powrtouch kit. Time will tell. |
Having used them now a couple of times out I found the tight turn very useful at the Cotswold site. The site is called Orchard lodge near Bibury. Lovely place and nice owner btw. I arrived to find I was allocated a pitch effectively facing me. Normally not an issue as there’s a good swing in from a large grass area but this was very soft and I would have caused serious damage dragging my van over it. The movers were employed to switch the caravan end to end in a pretty tight space. I was on gravel/pebble so it moved well. There was a moment of signal loss as stated but the engineer came to the site a few days later and the issue has gone, thank goodness. I would not have been able to have positioned the van as quickly or easily with the Powrtouch units even if they were working well. I did have to put the stones back in place with my foot to tidy up after the manoeuvre.
