Home > Technical (L322) > Auto Wipers
Page 5 of 6 <123456>
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
changing the pad is really easy i did mine last weekend i used some fuse wire to 'cut' behind the reflector to get through the glue (its really tough stuff) then just clean the area over with white sprit to remove any grease before applying the new pad - if ordering from that company (i got mine from there) they do charge a small fortune in postage (£8 for a part no bigger than half a 5 pound note!!! rip off, but was the only company i could find that sold them here in the UK)
Matt
Post #65676 24th May 2011 11:07pm
daveo
hi matt, is yours all up and working now... V8 facelift Range Rover Autobiography 22" wheels.
Post #65691 25th May 2011 8:03am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi Dave - I assume you mean new black trims down the left and right of the screen on the outside.? NO....
Should they have done or is it optional (unless they break them) Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #65694 25th May 2011 8:28am
daveo
well yes as they have to stick to the windscreen down the front edge to stop wind noise, unless they put sealer on them, how about the top trim Question was you there when they done it.. V8 facelift Range Rover Autobiography 22" wheels.
Post #65699 25th May 2011 8:56am
comports
No unfortunately not - Was at work. Wish I had been now though.! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #65700 25th May 2011 8:57am
mattstevenson2005
my LCM 4 arrived yesterday and had a go at fitting but my faultmate had an issue programming the brand new unit so i am just waiting for blackbox to sort the issue out
Matt
Post #65705 25th May 2011 10:24am
stevenA
2002 Range Rover Vogue Td6 Zermatt Silver
Will be interested to hear if Blackbox find a solution to programming your LCM - I read somewhere else that this was a big problem (although cannot remember where) - particularly if you manage to avoid the dreaded black spot!
They told me that they were unable to do new instrument clusters, and as the LCM works hand in hand with the IC....
Post #65720 25th May 2011 1:57pm
comports
OK - Update
Spoke with my friendly LR indy and I'm going to see him Saturday morning hopefully.
He has had a look through AutoLogic and said there is an option to enable/disable Auto Lights and/or Auto Wipers so it seems it is configurable.
He also said he should be able to configure the LCM to my car using Auto Lgic as well. If not, the LR T4 system will allow him to "install a replacement unit" that will re code to the chasis/mileage etc anyway. I guess this reads the chassis and mileage details from the cars systems and then programmes the new unit accordingly. That will get rid of the "black dot of death" for me.
£40 all in he said.. Happy days but will update you all once I've been down there. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #65853 26th May 2011 2:08pm
stevenA
Thanks for the update Comports - you definately have my attention!
Please let us know how you get on. My understanding is that the LCM is a "one time write" module - meaning that you can only initialise NEW modules with T4, at least with regards to the mileage - and so if you succeed in removing the black spot of death, this will be good news for all reading, even if it means paying a stealer.
I think that this has been the issue for all 3rd party diagnostics systems, which can change all, or most, other settings.
Post #65952 26th May 2011 10:07pm
comports
Managed to pop down to my mate this morning...
He did check and everything was already enabled (ie auto wipers and lights) but there is an additional setting in there for (something like) "Delay setting for intermittent (Overrides auto wipers)" which was also set.
Turned that bit off and hey presto everything works as it should..!
Didn't manage to clear the black dot but he is going to investigate with Autologic for that bit.
We did however come up with a fault on the light levelling however. Can you guys comment on this. When you start the RR do your lights go through a level check i.e. "Lower and raise the lights"? This happens on my CLK but I have never seen the FFRR lights move.? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #66010 27th May 2011 11:53am
my xenons dont do a level check on startup ash..
Post #66015 27th May 2011 12:11pm
comports
Thanks Mate... I may be ok then but will watch and see as I believe xenon's self leveling will form part of MOT soon.? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #66017 27th May 2011 12:15pm
dan_uk_1984
There is no self level check on our lights, the adaptive ones do check though - up/down left/right.
It's all immaterial really considering the suspension keeps the car level at all times... But they have to comply with legislation that doesn't consider the EAS.
Post #66021 27th May 2011 12:41pm
daveo
hi ash, i have a bi-xenon headlight with the adaptive built in as a spare light, they will not work on our cars, the need some commands from other modules and the steering sensor as well, on the later cars 06 and on they started fitting them and yes when you start they go up and down only.. thats interesting info you man found, i am sure you have said but what diag system does he use. i was told that on the LCM it was a code once only unit making it impossible to write to it again...but theres no such thing as impossible. V8 facelift Range Rover Autobiography 22" wheels.
Post #66059 27th May 2011 5:13pm
comports
Hi Dave - He used his AutoLogic system today to re programme it all. My car was showing up as a petrol as well for some reason so he went through a few bits. Turned on daylight running but I didn't like that so we turned that off again. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #66069 27th May 2011 6:48pm
