![]() | Home > Technical (L405) > Reverse mirror tilt problem |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8737 ![]() ![]() ![]() |
I think you put it in reverse, then set the mirrors where you want them when you select reverse, then go back to park or drive and they will return to where they were before but remember the reverse setting.... if that makes sense....!! Pete
tuki Member Since: 28 Mar 2018 Location: Istanbul Posts: 22 ![]() ![]() ![]() |
tried it but just the left side mirror tilts back, nothing with the right one. The car is acting like it's a right-hander. |
Both of mine can be adjusted that way... does that mirror adjust OK normally...? Pete
yep everything is working fine besides of the auto tilting function |
Maybe it's deeper in the settings and needs something in the CCF looking at... just guessing... |
Range Rover LSE Member Since: 15 Jul 2012 Location: Preston Posts: 47 ![]() ![]() |
You can turn the reverse dip feature on or off in the vehicle settings menu, the option sits in the convenience features section. Can be accessed through the Menu button on the steering wheel and scroll down. Range Rover LWB HSE L460
